nitrogen
Old Feb 15, 2007 | 03:43 PM
jan-db's Avatar
jan-db
Default nitrogen
Will nitrogen in run-flats affect the tire pressure sensors?
Old Feb 15, 2007 | 03:46 PM
Specter's Avatar
Specter
Air is somthing like 70% nitrogen so I doubt it.
Old Feb 15, 2007 | 03:47 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
You do know that the Earth's atmosphere, i.e., the air you breathe is 78% Nitrogen.
Old Feb 15, 2007 | 05:53 PM
DADEO1's Avatar
DADEO1
Default Nitrogen
The sensors read pressure only.
Won't matter.
Don't pay too much for it.
Way over priced through tire outlets.
Talk to your local welding supply store, they can help you.
(I sell industrial gases.)
I think there could be some advantage to it.
Pure Nitrogen has larger molecules and is very dry, no moisture.
However I do not use it, even though I can get it at cost.
Too much trouble, air compressor much eaiser.
But the above comments are correct 78 % nitrogen in atmosphere.
Old Feb 15, 2007 | 07:22 PM
robert123's Avatar
robert123
most think its
Old Feb 15, 2007 | 07:39 PM
R Devil's Avatar
R Devil
No.
Old Feb 15, 2007 | 07:57 PM
mitchcole's Avatar
mitchcole
Originally Posted by robert123
most think its
Because it is.
Unless the tire shop mounts the tires within a controlled atmosphere glove box, the air in the tire is whatever the atmosphere is. Adding straight nitrogen to that moist air will change the percentages, but not by a whole lot.
You'd need to cycle purge the tire about 10 times to get all the air out...but as soon as the pressure dropped below atmospheric by a significant amount, the bead would likely break.
Old Feb 16, 2007 | 03:58 PM
jan-db's Avatar
jan-db
Thanks for the good reponses. I only condidered it because racers (sprint cars) are using it.
Old Feb 16, 2007 | 04:45 PM
vettekid00's Avatar
vettekid00
I put it in mine and it ran 10 pounds highter than what was actually in them. Maybe just bad nitrogen.
To nitrogen
