oil sending unit!!
Old Feb 15, 2007 | 04:34 PM
rdbinc's Avatar
rdbinc
Default oil sending unit!!
Location of oil sending unit on 1998 C5!!
Thanks RDB
Old Feb 15, 2007 | 04:37 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
On the back on the engine under the intake manifold.
Old Feb 15, 2007 | 04:48 PM
rdbinc's Avatar
rdbinc
Thanks for the advise!
RDB
Old Feb 15, 2007 | 09:26 PM
berryj's Avatar
berryj
Here you go:
http://forums.corvetteforum.com/show....php?t=1472249
Old Feb 16, 2007 | 06:37 AM
PilotofCorvette's Avatar
PilotofCorvette
Don't waste your time pulling off the manifold as suggested above, cut the rear pastic panel and you will be done in 10 minutes.
See thread at top with photos
Sticky: Oil pressure sender relocate (Multi-page thread 1 2 3 ... Last Page)
426 Hem
Look at post number 63
Old Feb 16, 2007 | 07:01 AM
VinnyT's Avatar
VinnyT
Yup, I get to do it this weekend. Yippee!
Old Feb 16, 2007 | 06:43 PM
rdbinc's Avatar
rdbinc
Thanks alot for the help.
Look like i have my work cut out for me this weekend!!
RDB
Old Feb 16, 2007 | 06:59 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Sending Unit
I thought I was home free......after 121,000 it took a crap. I didn't know about cutting the plastic above the unit. I removed the intake, oh well, at least I learned something new.
Old Feb 16, 2007 | 08:43 PM
RedC5's Avatar
RedC5
Damn....mine just failed today!
Old Feb 17, 2007 | 01:46 AM
N0TDADYS_98's Avatar
N0TDADYS_98
just replaced mine for the 2nd time in a month.... it's the cold air i'm sure... and the oil i'm using... to much oil pressure... if i run through the gears and push to redline.. i bet i pop the oil pressure sensor every time.. good thing after the first one the rest are free..
Old Feb 17, 2007 | 08:59 AM
berryj's Avatar
berryj
Before you embrace the easy cut away method, look at these issues raised recently. You might find that other annoyances can arise by doing this. Perhaps the relocation method might be better:
Originally Posted by N0TDADYS_98
i realized that the engine bay is already cluttered enough... so i decided to say away from the relocation... i did the cutting mod... and as scared about cutting my car as i was... it all turned out ok... after you do it once it's a piece of cake...
My local parts house has a life time warranty on my BW sensor... So i can replace it weekly if need be... i requested they stock the part... if i blow enough of them up, i'm sure they will figure out a way to prevent such a problem...
actually with this nice little hole, i'm thinking my engine bay actually might stay a little cooler this summer.
For all those that dont recover the hole, think about this; The HVAC intake takes a suction from that area. Any holes in that area may allow engine fumes and heat to enter the HVAC systen and make its way inside your cabin. Just something to think about.
BC
Here's the link:
http://forums.corvetteforum.com/show...1588172&page=4
Old Feb 17, 2007 | 09:34 AM
screw991le's Avatar
screw991le
426 Hem
Cool Mod
Old Feb 17, 2007 | 09:38 AM
SlideRulz's Avatar
SlideRulz
I just had mine replaced at the Dealership, $373.00
I have a extended warranty so my cost was $100.
To oil sending unit!!
