Corbeau Forza II Install
I had a forum member ask me if the stock seat belts could be retained with the Forza II and at the time I didn't know because I had not tried it. After I investigated a little I came to the conclusion that the stock seat belts deffinately could not be retained using the G-Force harness due to the size of the bolt brackets on the lap belt. The bolt in brackets were too large to use the stock seat belt bolt on the door side while the seat belt was installed. That is not the case with the Schroth harness. The ends of the harness are bendable and much smaller than the G-Force harness. I have a few pics that will illustrate how I made the door-side lap belt fit with the seat belt retractor.
Now, I said that the door side of the seat belt can be retained but with the seat I have(Forza II is wider than the standard Forza) the seat belt receptacle will not fit between the seat and the tranny tunnel. I show a pic where the receptacle is bolted onto the seat and I am sure with the standard Forza seat it will work as pictured but it WILL NOT work with the Forza II. I do not have any experience with any other harness brands or models so I have no idea if they will or will not fit.
Here are a few pics
This is the lap belt connected to the seat track using the bolt from the stock seat track. I had to have a friend sit in the seat on the ground while I used a large rubber mallet to bend the lap belt bolt bracket in toward the seat about a half an inch. I tried to install the seat before I bent the bracket and the bolt kept binding on the carpet. You may be able to make it fit but I recommend bending the tab.
The receptacle connected in addition to the Schroth harness(I did not install my seat like this)
With the Schroth harness you get bendable bolt tabs. The door-side lap belt tab needs to be bent like you see in the pic. If the belt is laying on a surface with the pull tab facing up you want to bend the tab up 90 degrees.
Then you will install the belt as seen in the pic. It is installed on the same bolt as the lower seatbelt retractor.
Then you can re-install the plastic trim.
Then I recommend installing the shoulder belts. I have Gary's Hardbar. Which I strongly recommend if you don't have a harness bar or roll cage.
If you have Gary's Hardbar you can bolt the stock shoulder belt bracket to the harness bar as shown.
After the shoulder belts are installed you can put the seat in. With the Forza II the fit is very tight and it took some work to get all of the bolts to line up with the seat slider. I'm sure it will be much easier with a narrower seat. After the seat is installed you can feed the belts through the holes and you are done.
I had a set and they were very comfortable. The only problem was, they didn't fit with my existing roll bar. I didn't feel like having it cut out and having a new one installed, so I had to put the stockers back in.
They are comfortable for long stints in the car but the hard part is getting in and out.
what did you do about the seat belt light? I am in the middle of installing a pair of Corbeau A4's and have a feeling the seatbelt light is going to permenantly be on unless I can figure out what pins to jump on the connector under the seat...
TIA
As far as the door closing. The door very lightly touches the door panel. It's not an issue but it did make me nervous before I got the thing completely installed.
