oil pres sender
Old Feb 18, 2007 | 01:28 PM
emj's Avatar
emj
Default oil pres sender
I am getting ready to change the sender. Refering to Victorz' description of the procedure, it is necessary to remove the coolant hose that goes to the throttle body. Question: does the coolant need to be drained from the radiator, or is there air in the line at this point?
emj
Old Feb 18, 2007 | 07:53 PM
emj's Avatar
emj
Disregard the question...I figured it out. Victorz post for the procedure is excellent. It took 4 hours. If I have to do it again I believe I could do it in 1 1/2 - 2.
