Black Box on C5...need help...urgent
Old Oct 7, 2001 | 05:38 PM
vette-crazy's Avatar
vette-crazy
Default Black Box on C5...need help...urgent
Do any of you guys now if GM looks at the black box when you take your car in under warranty with engine trouble?
Worried for a friend who might have over reved his car and don't know if GM will point a finger at him for over reving the car.
Old Oct 7, 2001 | 07:39 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Black Box on C5...need help...urgent (vette-crazy)
No...The SDM (sensing diagnostic module) or black box which some call it for some reason,retains crash data at the time of air bag deployment only.
On the other hand,if you stored an emissions related fault code for some reason,we can tell the mph and rpm at the time of the fault,along with all other data parameters...That data is stored in the PCM history...
Old Oct 7, 2001 | 10:35 PM
chuckster's Avatar
chuckster
Default Re: Black Box on C5...need help...urgent (C-5 TECH)
Not if cleared by an Autotap :D :D
[Modified by chuckster, 8:36 PM 10/7/2001]
Old Oct 7, 2001 | 11:04 PM
ProDesign's Avatar
ProDesign
Info available at:
http://www.c5-corvette.com/gm_black_box.htm
Old Oct 8, 2001 | 01:17 AM
Gary2KC5's Avatar
Gary2KC5
Default Re: Black Box on C5...need help...urgent (chuckster)
Not if cleared by an Autotap...
chuckster,
Does the Autotap clear out the black box too or just the PCM/DTC?
There might be enough info from the DTC to cause some concern from the dealer. Holding the options button while pressing the fuel button quickly 4 times will display the codes (have pad & paper ready)
On one hand I say if I over-revved and bend a pushrod I should pay for that but on the other hand how can GM allow this to happen. Doesn't look like the fuel cut-off protects like a rev limiter would.
[Modified by Gary2KC5, 11:24 PM 10/7/2001]
Old Oct 8, 2001 | 12:04 PM
1fastdog's Avatar
1fastdog
Default Re: Black Box on C5...need help...urgent (Gary2KC5)
No rev limiter on the planet is going to save parts from a mechanical over rev when shifting to a lower gear when looking for a higher one...
If ya wann play ya gotta pay.
Old Oct 8, 2001 | 12:39 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Black Box on C5...need help...urgent (1fastdog)
You are correct sir! I guess I was just thinking about mine own issue with wanting to keep my foot in it as long as possible.
Old Oct 8, 2001 | 03:05 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
No doubt. missed third, and dropped into 1st :eek:
The tires tend to lock up when mis-downshifts happen (especially with the crappy stock shifter), and make the engine over rev.
To Black Box on C5...need help...urgent
