Headlight Malfunction
Old Feb 19, 2007 | 03:59 AM
C5Joe559's Avatar
C5Joe559
Default Headlight Malfunction
I was at the mall with my girlfriend this evening, and as we were about to leave I turn on my headlights, but they didn't open. It's a 2000 Chevrolet Corvette, the fog lights and gauge cluster light up, just they don't open. I'm hoping it's just a fuse and that I don't have to replace the motor for this. Anyone else ever had this problem? Any help would be greatly appreciated. Thanks.
Old Feb 19, 2007 | 04:46 AM
Blown 346's Avatar
Blown 346
Did you hear and grinding?
Old Feb 19, 2007 | 05:16 AM
C5Joe559's Avatar
C5Joe559
I'm sorry what? I'm talking about the flaps for the headlights. They don't come up when I turn my lights on.
Old Feb 19, 2007 | 05:39 AM
SpeedyD's Avatar
SpeedyD
Sorry for laughin, he knew what you were talking about, the "transmissions" for the headlights are notorious for going bad, they have plastic gears. So he wanted to know if you heard grinding because that would have meant you spent the gear inside. But if both lights aren't coming up it's more than likely a fuse or some other electrical aspect. Check fuses first and then you might have to test the switch. Good Luck!! Dan
Old Feb 19, 2007 | 09:16 AM
C5Joe559's Avatar
C5Joe559
Oh, my bad then. I dont hear anything, they just won't come up. I'll be checking the fuses today, and I'll let you guys know how that goes. Thanks for the help.
Old Feb 19, 2007 | 10:01 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Do the lights themselves come on, but don't flip up?
Old Feb 19, 2007 | 10:30 AM
Oldvetter's Avatar
Oldvetter
Remove, clean and tighten your battery connections. Or just see if one is loose, can you turn cable by hand? Only tighthen to 11 ft-lbs, over tightening this causes leaks in nonglass mat batteries. Your computer is below the battery.
Old Feb 19, 2007 | 01:40 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its possible if you parked under a street light in the parking lot, there might have been enough light to fool the system. First thing is to turn them on using the headlamp switch on the stalk. If they came up, you've got lights. Another thing is turn off the headlamp switch, then turn off the twilight sentinel in the DIC, then turn on the headlamp switch again. If they work, then you have isolated several things. The headlamp switch itself and the motors. That leaves the headlamp controller which is mounted on the '99 on the right frame rail, behind the right headlamp. It will cause this problem. There are about 4 relays that will also cause issues. Two are in the passenger footwell and the others in the engine fuse box, but only if they stop raising. Oh, one other thing, did the headlamps turn on even though the doors remained closed? If so, the headlamp controller.
Old Feb 24, 2007 | 04:42 AM
C5Joe559's Avatar
C5Joe559
I checked the fuses, and non of them seem to have gone out. The lights don't actually turn on, but I would think that they would at least open...right? Sorry for the noobish questions, just that my 92 Supra has lights like these and they still pop open even if the bulbs are out. So if the bulbs are burnt out, then they will not open!? Correct? Weird how they both would go out at the same time.
Old Feb 25, 2007 | 10:28 AM
C5Joe559's Avatar
C5Joe559
I've read all the stickies, and searched the whole forum about the gears. My car doesn't make any noises at all when I open or close my headlights. That must mean it's the motor, correct?
Old Feb 25, 2007 | 01:10 PM
BowTieRocket's Avatar
BowTieRocket
I have the same problem intermittently with my 1999 coupe. It has been so intermittent I haven't dealt with it, but I notice it's more pronounced if the indicated voltage is below about 13.5v.
The first thing I want to do to try to fix this is apply Bill Curlee's information on cleaning the grounds. It acts like it's a low voltage situation. Sometimes the lamps have come on but the doors don't open, but more often, the lamps stay out and the doors stay down. No grinding noises, nothing like that. And if I come back to the car a bit later, they'll usually work.
Late last summer this resulted in the embarassment of driving my Mustang (1969 GT500) to the Corvette club meeting. I figured it was better than the company-issue generic Ford Taurus...
I'll watch this thread to see if anyone else has addressed this, and if my guess on compromised grounds is on track.
Old Feb 25, 2007 | 01:54 PM
C5Joe559's Avatar
C5Joe559
Nice cars, thanks for the reply. Good thing you have the garages seperated, or else that may be a sin.
Old Feb 26, 2007 | 11:58 AM
dgrant3830's Avatar
dgrant3830
If they don't open, yet the lamps are on, high probability that its the headlamp controller module.
Old Feb 27, 2007 | 07:56 AM
C5Joe559's Avatar
C5Joe559
Lights don't come on either. I've heard that they should still open even if the lights don't come on, is that a correct statement?
Old Feb 27, 2007 | 10:39 AM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
With mine, the lights came on but doors wouldn't open. The headlight door control module was bad. Maybe You have two problems??
There are fuses for headlamps both under the hood and under passenger side foot rest.
Old Feb 27, 2007 | 12:18 PM
C5Joe559's Avatar
C5Joe559
I'll check into the module today. Thanks for the replies everyone, it's greatly appreciated.
Old Mar 4, 2007 | 04:41 PM
jkapron's Avatar
jkapron
4th Gear
Default Grinding
My lamps are grinding and the controls are not working properly, the lights work fine when up, any thoughts?
To Headlight Malfunction
Old Mar 4, 2007 | 09:56 PM
2KFRC5's Avatar
2KFRC5
Will the headlights turn on if you pull back on the flash-to-pass?
Check: HEADLAMP RELAY GROUNDING
Old Mar 5, 2007 | 06:12 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Perhaps the headlight stalk itself is bad. My stalk went bad when i pulled back to do a flash-to-pass and the stalk jammed in that position. I proceeded to push it back into the neutral position...thats when i heard a snap...from then on, everytime i turned the headlights on, i was always in flash-to-pass mode (AKA high beams)...i bought a new stalk and it fixed everything...
Old Mar 5, 2007 | 10:02 PM
jkapron's Avatar
jkapron
4th Gear
Default grinding
Found out it is the gear in the lamps, changing it out fri, I'll to get the electronics checked out in the staff
