just pads ok?
Old Feb 19, 2007 | 01:11 PM
Sparky22's Avatar
Sparky22
Default just pads ok?
If my rotors are in good shape on my 02 z is it alright to replace just the pads without touching the rotors? I just don't like all the brake dust and I don't track the car so I was thinking of going to a less dusty pad. Also, do the base c5 pads dust less than the Z06 pad? I've herd ceramic pads dust much less and you don't lose too much preformance. So what is a good ceramic, or should I just live with washing the wheels every 2 days?
Old Feb 19, 2007 | 01:30 PM
VetteDrmr's Avatar
VetteDrmr
1. You don't have to replace the rotors.
2. Z06 pads dust more than stock OE pads
3. Ceramic pads dust the same as OE pads, but the dust is less visible (the pads are less effective, also)
HTH, and have a good one,
Mike
Old Feb 19, 2007 | 10:27 PM
oldschoolvette's Avatar
oldschoolvette
true
Old Feb 19, 2007 | 11:54 PM
TEXHAWK0's Avatar
TEXHAWK0
If the pads have not worn a lip on the edge of the rotors and they are not pulsing, you can probably get away with replacing the pads and not turning the rotors. I have done that with no problems. In fact, the factory service manual says that machining the rotors should NOT be part of normal maintenance.
That said, most all shops machine the rotors as part of a brake job, but I think it is mostly to avoid problems with brakes making noise, not brake performance.
Old Feb 20, 2007 | 09:47 AM
Sparky22's Avatar
Sparky22
Thanks guys, any sugestion on ceramic pads?
Old Feb 20, 2007 | 09:53 AM
MTurnbo's Avatar
MTurnbo
I bought GM ceramic pads and if they do dust the same as OEM, as has been said, it certainly doesn't show. Performance wise, unless you track the car you'll not notice any difference.
Old Feb 20, 2007 | 10:12 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Nice, concise evaluation Mickey..so the dusting is less and a lighter color?
Old Feb 20, 2007 | 10:50 AM
berryj's Avatar
berryj
I thought the OE GM pads were ceramic?
Old Feb 20, 2007 | 02:32 PM
Old Feb 20, 2007 | 09:52 PM
VetteDrmr's Avatar
VetteDrmr
Never, ever, ever, ever, EVER, turn C5 rotors.
1. Finding a competent shop with equipment less than 50 years old isn't that easy
2. Those that have the equipment won't do it for free
3. Most importantly, new OEM rotors can be had from NAPA for less than $30 each.
My rotors have had a "lip" on them for almost 50K miles, 8 track sessions, and 2.5 full autocross seasons under them. The lip means nothing.
Mike
Old Feb 20, 2007 | 10:01 PM
LoneStarFRC's Avatar
LoneStarFRC
Nope. GM offers them, along with many others, as a replacement pad for those that want to use them. They were not original equipment.
Old Feb 20, 2007 | 10:03 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
no reason to turn rotors. Go buy new ones from NAPA at $25 each.
You can change just the pad, but make sure you flush the brake fluid. If you went through a set of pads then it is time to get some new brake fluid.
Valvoline Synpower Dot3/4 is good for everyday driving.
Old Feb 21, 2007 | 08:46 AM
berryj's Avatar
berryj
What are the OE pads made of?
Old Feb 21, 2007 | 10:29 AM
jovette's Avatar
jovette
Mike
I agree, don't turn the rotors, however, it'd be fine to take an electric drill, with a sanding disc. and clean up both sides of the rotor. It'll put swirll marks on the rotor and clean off the rust on the rotor lip/edge, and make help prevent brake pad squeal. I did this to my rotors when I installed new ceramic brake pads, and I am very happy with the results, since the wheels don't look nearly as dirty after driving a couple of hundred miles.
Old Feb 21, 2007 | 10:06 PM
LoneStarFRC
Semi-metallic.
Old Feb 21, 2007 | 10:13 PM
Billf6531's Avatar
Billf6531
Exactly! I use a small orbital sander. Same result. Then a spray can of high temperature silver paint, or your choice of colour, and spruce up the hub and rotor edge/vanes. You'll be pleased.
Old Feb 21, 2007 | 10:14 PM
Ralphyboy's Avatar
Ralphyboy
I'm concerned now.Don't cut the rotors?When I got my C5, there was a pulsation in the brakes. The dealer replaced the pads and turned the rotors. I've read that they are pretty inexpensive, but the car brakes OK now. Does turning them weaken them by reducing the meat on them? The dealer which has Dodge and Chevy products at different locations said that they checked with their Chevy mechanics, and it was OK to machine the rotors. What's the real deal here?
To just pads ok?
Old Feb 21, 2007 | 11:26 PM
2blklt4's Avatar
2blklt4
...the deal is that rotors are so cheap it would cost you jst as much to turn them
Old Feb 22, 2007 | 08:24 AM
VetteDrmr's Avatar
VetteDrmr
One reason is that brakes main purpose is to act as a heat sink, and thermal mass is one of the main characteristics of a brake rotor. When you get the rotors cut, it reduces that mass.
At least as important to me is the fact that turning a rotor isn't something an unskilled mechanic can do right. If the mech doesn't get the rotor seated absolutely square on the lathe, a wobble will be cut into the rotor, ruining it. (ask me how I learned that one!). If the lathe isn't true, same result.
And, as has been mentioned, brand new rotors from NAPA are so cheap as to just make the rotors throwaways.
Mike
Old Feb 22, 2007 | 11:01 AM
Sparky22's Avatar
Sparky22
My question was that I want to chang just the pads because of all the dust, the pads on there now are not worn out and there is no rust or lip on the rotors so can I just change the pad if the rotors are in good shape? Do I really need to chang the brake fluid?
Also since I have a Z06 I believe they come with a carbon pad,= lots of dust. Im I correct on that?
Some suggestions on a ceramic pad.
