0-60 times??
Old Feb 20, 2007 | 11:24 PM
Kingman99's Avatar
Kingman99
Default 0-60 times??
Hi
For some reason l can't find a thread regarding 0-60 times.
I have an 02 coupe auto with the perf rear 3.15. What should l expect run and if l add a blackwing howmuch should l expext.
All l need is an approx
Alan
Old Feb 21, 2007 | 02:13 AM
PDQC5's Avatar
PDQC5
My 98 A4 w/ a 3.15 ratio went 13.30 @ 105 MPH with a 2.00 60 ft. the only mod is exhaust (flowmaster catback).
Old Feb 21, 2007 | 11:59 AM
robert123's Avatar
robert123
I believe I read 4.7 sec. somewhere.
Old Feb 21, 2007 | 03:40 PM
SpeedRacer C5's Avatar
SpeedRacer C5
I have a 2000 Auto w/ intake, headers, and B&B PRT and ran 1.913 0-60ft and 12.6 quarter @ 109.96.
Old Feb 21, 2007 | 03:54 PM
B-ras's Avatar
B-ras
Figure about 4.3 for a Z06 up to about 5.0 for an early 2.73(?) auto. Lots and lots of variables for launch, surface, etc. I think your car would be in that 4.7-4.8 range. Sorry, but a Blackwing alone won't make much diff, maybe a few thousandths IMO.
Old Feb 21, 2007 | 06:55 PM
Bluefire's Avatar
Bluefire
Originally Posted by kingman
Hi
Alan
Try this.... http://www.albeedigital.com/supercou...0-60times.html
Old Feb 21, 2007 | 06:59 PM
Vettedreamer2's Avatar
Vettedreamer2
Are you asking 60ft times - as in a strip start
or
Are you asking MPH as in 0 to 60mph times??
Old Feb 22, 2007 | 09:19 AM
tabbruzz's Avatar
tabbruzz
I thought it was 5.05 from the factory....
Old Feb 22, 2007 | 10:56 AM
electronbluec5's Avatar
electronbluec5
Is there a particular reason you want 0-60mph times and not 1/4 mile times? 0-60mph times, I guess, are good for impressing people that really don't know much about cars but they are generally a bad judge of how fast a car is. For example, the C6 Z06 reaches 60mph in first gear just after redline so in that case you are just measuring how fast it can wind out one gear. Shifting is not necessary so who knows if it can jam through the gears or if you are going to have to take a nap between gears. I know that the C6 Z is very fast but I'm just trying to make a point. A car like the C5 Z can be just as fast but adding a shift into the 0-60 time will slow it down a couple of tenths.
The better judge is the 1/4 mile. Generally a street car will shift at least three times(the faster you go the more you shift) over the 1/4 mile so it really tests the car better. If you don't get out of the hole you will have a slow run. If you miss shifts you will have a slow run.
Over all the 1/4 is a much better judge of a cars straight line performance.
Old Feb 22, 2007 | 08:40 PM
DKHIGHPERF's Avatar
DKHIGHPERF
Default mt C5 A4 is stock
My 2001 C5 Coupe is completely stock with A4 and 3.15's. 0-60 was 5.02 with my friends g-meter and my best qtr is 13.44sec. at 104.7mph
DKHIGHPERF
Old Feb 22, 2007 | 08:56 PM
Kingman99's Avatar
Kingman99
Default Good point!
Well taken your right about 0-60 times.
thanks
Alan
Old Feb 22, 2007 | 10:55 PM
docohm's Avatar
docohm
My 2001 A4 w/ 3.15 rear end does 5.07 secs on 0-60 mph. I have flowmaster mufflers and a K&N intake but I don't think those things really help anything but the SOUND and they DO SOUND NICE.....
That's measured with the stock Goodyear tires on asphalt on a rather cool day so it might get a little better on a warm day when the tires hookup better.
STW, Doc
To 0-60 times??
