Runflat Mileage?
Old Feb 23, 2007 | 08:44 PM
whiplash 1's Avatar
whiplash 1
Default Runflat Mileage?
I many miles can I expect to get out of a new set of Goodyear runflats?
Old Feb 23, 2007 | 08:53 PM
2blklt4's Avatar
2blklt4
got 22k on mine and still plenty of meat left
Old Feb 23, 2007 | 08:56 PM
whiplash 1's Avatar
whiplash 1
I have heard some people say 25,000 is about all you can expect? I was hoping to get at least 30,000 out of mine.
Old Feb 23, 2007 | 08:57 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I bought my car with 40883 miles on original runflats. I have put about 7500 on her since and I just measured the rears - 5/32" +/- tread left. Just a streeter to date but the longer I own the Silver Bullet the more the rear tires seem to spin. Most folks say a streeter can get 55-60000 out of a set,,,not much more though. When they get a little lower it will be new tires, wheels, rotors, calipers time,,,, part of the "PLAN".
Old Feb 23, 2007 | 09:11 PM
whiplash 1's Avatar
whiplash 1
50,000 miles out of a set sounds GREAT to me!!
Old Feb 23, 2007 | 09:24 PM
robvuk's Avatar
robvuk
50,000 miles!!! Do you ever start the engine? Or do you just push it everywhere.
Old Feb 23, 2007 | 10:19 PM
brucemoose2's Avatar
brucemoose2
Old Feb 23, 2007 | 10:33 PM
robvuk's Avatar
robvuk
I think somebody was yankin' your chain. It was probably at LEAST the second set of tires. Maybe even the third.
Old Feb 23, 2007 | 10:39 PM
Oldvetter's Avatar
Oldvetter
I get 45,000 miles from back tires and 55,000 miles on fronts.
Old Feb 24, 2007 | 12:32 AM
KABAL182's Avatar
KABAL182
i got 35k on mine ,very important keep a eye on your tire pressure. run them 30lbs cold
Old Feb 24, 2007 | 01:15 AM
Billf6531's Avatar
Billf6531
Actually, the prime key to long life is getting the camber set to as close to zero as possible, front and rear. Otherwise they'll wear the inside 1" or so to the cord, and have zillions of kilometres left on the rest of the tire. Ditto on the tire pressure.
Edit: I use my car for touring, not racing, so long tire life is important to me, but I agree with everyone who says the tires give a rough ride. Fortunately, we have well paved highways (mostly) so it's not that big an issue.
Old Feb 24, 2007 | 02:11 AM
jlcvt's Avatar
jlcvt
WOW 25, 35, 45,000 that’s great. Me about 10,000, with proper air pressure and alignment.
Old Feb 24, 2007 | 06:59 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I have a little over 36,000 on my original run-flats. They are still fine but getting towards the upper end of life. They have somewhere between 5-10K left on them. There are a lot of factors that affect tire life, so it doesn't surprise me that folks have variances in the numbers. Some of the lowest numbers in this thread seem too low to me though. On those it sounds like something was out of adjustment.
Old Feb 24, 2007 | 01:14 PM
brucemoose2
If you drive aggressively and have a "strong street" or "track" alignment done, you'll be running with lots of toe-out (technically, your alignment will be out of spec) for quick steering response. This will decrease your tire life, but steering response will be stellar. This is likely part of the reason why "your mileage may vary"...
Old Feb 24, 2007 | 02:52 PM
C5XTASY's Avatar
C5XTASY
18K from my original set, and that wasn't abusing the car. I went to Michelin Pilot Sport AS Z/P's and heads, cam, longtubes, SS3200 stall, etc, etc., and have 40K now with plenty of tread left. Dump the Goodyears....no comparison.
Ed
Old Feb 24, 2007 | 05:34 PM
Bill Dearborn's Avatar
Bill Dearborn
I went through 3 sets in 18K. Depends on how you drive the car.
Bill
Old Feb 24, 2007 | 07:28 PM
TOMMYTRB's Avatar
TOMMYTRB
I got 37,000 on my GY emts very loud tire.
Going to try Michelin Pilot Sport AS Z/P's or Firestone's Firehawks
To Runflat Mileage?
Old Feb 24, 2007 | 11:56 PM
whiplash 1's Avatar
whiplash 1
I have heard these tires are loud but figured I wouldn't notice them over my headers and borla quads? I am more concerned with how much mileage. Seems like a lot of factors will determine mileage ie. Burnouts, tire pressure, alignment, etc. I was looking for an average.
Old Feb 25, 2007 | 12:31 AM
RossJackM's Avatar
RossJackM
My DD has 65500 on Firestone Firehawk Runflats... Put on at 29800, back in 2002.. They need replacing, less than 2/32, basically driving to work. I understand that this is typical.
Old Feb 25, 2007 | 08:22 AM
Irish Whiskey's Avatar
Irish Whiskey
You will get far too many miles -put on the GSD3's and you'll be glad!!
