ok, this G5X3 swap is adding up fast, so far i'm $1300 in parts
but yea, this is the final piece of the puzzle. What would I need to get an LS2 chain in my Z? Is it a direct replacement?, I was worried about maybe the sprockets are different also and may need to be doing some modifying. I work at GM, so I preferred to use GM parts since I get it at cost instead of buying some kit. is it possible?
Me too .....but I would supplement this with the chain dampner. If it is a pre '04 ls6 block , you need the dampener out of the GM Performance parts catalog. FWIW, I too used the 04 LS6 and later Ls2 chain (same) on the stock previous LS6 sprockets.
