Looking for TSB...can someone post?
Old Feb 24, 2007 | 01:55 PM
pylant's Avatar
pylant
Default Looking for TSB...can someone post?
Can someone post TSB # 030730042 NHTSA ID # 10004324?
Deals with the leak from the transmission.
I found plenty of sights that list TSBs but none that have the whole discription.
tks
Old Feb 24, 2007 | 02:58 PM
JH's Avatar
JH
tks
Hmmm, when I go to the NHTSA site, and enter the code you provided, there is a list of the TSBs. But you are correct in that there is no substantive data or information. Here is the site for others, and the NHTSA number (enter just the numbers) is 10004324
The date of the bulletin is Sept. 1, 2003. That is probably why the '04 model is not listed.
http://www-odi.nhtsa.dot.gov/cars/pr...sb/results.cfm
Old Feb 24, 2007 | 03:20 PM
pylant's Avatar
pylant
You are right...that's the problem. Just thought someone would have paid to print the TSB or have access to dealer information.
I suppose a dealer would give me the information but was hoping someone on CF would have it.
tks
Old Feb 24, 2007 | 03:30 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
I have a friend at the dealer but service isn't open on Sat. If you can't find anything, shoot me a PM on monday and I'll call him. See if he can dig up somethin..
Old Feb 24, 2007 | 04:01 PM
Oldvetter's Avatar
Oldvetter
Here it is:
Document ID# 1381949
Automatic Transmission Fluid Leak at Rear of Vehicle (Replace Rear Output Shaft Seal With New Design Seal) #03-07-30-042 - (Sep 15, 2003)
Automatic Transmission Fluid Leak At Rear of Vehicle (Replace Rear Output Shaft Seal With New Design Seal)
1997 - 2003 Chevrolet Corvette
with 4L60E Automatic Transmission (RPO M30)
Condition
Some customers may comment on a fluid leak from the rear of the vehicle. This condition may be more likely to occur when the temperatures are below freezing.
Cause
The rear output shaft seal (106) may take a set in cold weather, allowing the seal to leak.
Correction
Diagnose the source of the fluid leak. Refer to Fluid Leak Diagnosis (SI Document ID #403256).
If diagnosis of the transmission fluid leak determines that the leak is from the rear output shaft seal (106), continue with the next step.
If diagnosis of the transmission fluid leak determines that the leak is from a location other than the output shaft seal (106), continue with the appropriate service procedure.
Remove the transmission from the vehicle. Refer to Transmission Replacement (SI Document ID #710311).
(106) Case Oil Seal Assembly (Corvette Only)
Replace the rear output shaft seal (106), P/N 24228816. Refer to Case Bushing Replacement In the Unit Repair Manual (SI Document ID #589612).
Reinstall the transmission in the vehicle. Refer to Transmission Replacement (SI Document ID #710311).
Road test the vehicle and confirm that all leaks have been repaired.
Parts Information
Part Number
Description
24228816
Seal, Rear Output Shaft (106)
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
K6360
Seal, Extension Housing Rear - Replace
Use Published Labor Operation Times
Click on the embedded link for the picture.
But that seal is inside the transmission, it doesn't look like a DIY job !
Old Feb 25, 2007 | 08:42 AM
pylant's Avatar
pylant
Originally Posted by Oldvetter
Here it is:
Condition
Cause
Correction
Parts Information
Part Number
Description
24228816
Labor Operation
Description
Labor Time
K6360
Thanks for the post. That's what I was looking for.
Your right...it is in the transmission it's going to be a job but it can be a DIY given patients and some basic hand tools and jacks. All depends on how much a person wants to save on labor cost which would run about one grand on this project. Saving a grand is important to me. I know I'm a cheap bastard...or so my wife says.
Thanks for the help.
Old Feb 26, 2007 | 01:32 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
It was just under $600 total at my GM dealer. If you're getting quoted a grand.. go to another dealer.
Yes, it can be done in your garage... but big PITA. The engine has to angle up, torque tube down, and you only get a couple inches before the engine hits the firewall.
Ugly job at best.
To Looking for TSB...can someone post?
