Engine Hesitating
Old Feb 24, 2007 | 08:44 PM
jcnsandiego's Avatar
jcnsandiego
Default Engine Hesitating
I need some help or suggestions with my 99!
At low R P M the engine is hesitating when I accelerate and sometimes misses at high R P M. Can anyone help?
Old Feb 24, 2007 | 08:59 PM
CorvetteTechInc's Avatar
CorvetteTechInc
The obvious things to check would be plugs and wires (arcing or disconnected, plugs burnt or fouled). If all plugs and wires are find I might suggest finding someone with a Tech II scanner and check for misfires, sensors, injector tests, etc.
Is the car throwing any codes?
http://www.corvettedoctor.com/Code_Main.html
Old Feb 24, 2007 | 09:15 PM
jcnsandiego
No it's not setting any codes. I will change plugs and wires and see if that helps.
THANKS FOR THE HELP!
Old Feb 24, 2007 | 11:16 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check out the PCV valve and the small line connecting it to the intake port. On my '99, it was doing the same thing then found a large hole on the bottom side of the rubber connector to the intake..hidden from view.
Old Feb 25, 2007 | 12:07 PM
jcnsandiego
Cool I will check that too.
Thanks I need all the help I can get!
Old Feb 28, 2007 | 11:19 PM
jcnsandiego
Default Thanks Again!!!!
I Found A Leak On My Pcv Hose At The Valve Cover.
Now The Car Runs Great!!!
Old Feb 28, 2007 | 11:55 PM
dgrant3830's Avatar
dgrant3830
Something I just recently found when I was doing the oil pressure sender relocation...I discovered that the cross-connect line for the PCV going from the left valve cover to the right valve cover, at the joint between, the rubber connection had disolved back there where no one can see it. The new replacement for it is a hard-plastic tubing assembly for it. I doubt this would cause any problems running-wise, but oil residue buildup and drippage on the rear of the engine would cause oil burning smell. Something to look out for.
Old Mar 1, 2007 | 12:06 AM
FRCTony's Avatar
FRCTony
Good tip!
To Engine Hesitating
