Please Help - Car is loping after install
Old Feb 27, 2007 | 02:01 PM
VetteFanatic007's Avatar
VetteFanatic007
Default Please Help - Car is loping after install
I installed a Blackwing on my 99' Coupe about two days ago. A few minutes ago while sitting at stop light, I noticed that the car was Loping. It would idle normal, and then the rpm's will drop as if it wanted to conk out. It is really noticeable while the A\C is running. I am new to the forum, so PLEASE help.
Thank You,
VF007
Old Feb 27, 2007 | 02:56 PM
kromberg's Avatar
kromberg
Have you done the idle relearn procedure yet?
Keith
Old Feb 27, 2007 | 02:58 PM
hotwheels57's Avatar
hotwheels57
...also, double check that you've made the connections air tight at the throttle body, air bridge, MAF, BLACKWING inlet, air pump hose and electrical connections.
Old Feb 27, 2007 | 03:54 PM
VetteFanatic007
I do not know what the idle relearn is. I will double check the connection to make sure that they are air tight. I will keep you posted.
Old Feb 27, 2007 | 04:06 PM
kromberg's Avatar
kromberg
Idle Relearn Procedure sent via PM. I had the same problem when I installed my first intake mod; Vortex Ram Air intake.
Keith
Old Feb 28, 2007 | 11:54 AM
Sox-Fan's Avatar
Sox-Fan
PMs are great, but they don't help the next guy.
http://forums.corvetteforum.com/show....php?t=1415236
To Please Help - Car is loping after install
