Slight performance upgrade questions.
Old Feb 28, 2007 | 09:06 AM
niemann_mark's Avatar
niemann_mark
Default Slight performance upgrade questions.
I have a 2000 vert. Stock LS1/A4. I am putting on a bassani X-pipe and exhaust, installing 3.42 gears. I am thinking of putting in a Z06 cam/spring/rods. What kind of performance gain should I expect from the cam change? Is it worth replacing with a Z06 one or should I get something else? I am not really wanting to make it super fast or anything just a little quicker, with all the 400hp stock cars that are and will be coming out.
Old Feb 28, 2007 | 09:08 AM
chaase's Avatar
chaase
St. Jude Donor '12
If you are going to spend the money on a cam swap, I would get something more aggressive. I also didn't see headers and torque converter on that list.
Old Feb 28, 2007 | 09:11 AM
Frizzle86's Avatar
Frizzle86
don't waist ur cash on a tiny zo6 cam. there are plenty of cams that are just as quite as the z06 cam and will net u more HP
C5LawnGnom's Avatar
C5LawnGnom
You should be expecting anywhere from 25-60 horsepower, and pretty decent gas mileage. Gear ratio is perfect for driving, and still powerful for draggin Like chaase said, no headers on that list
Old Feb 28, 2007 | 09:16 AM
94legaleagle's Avatar
94legaleagle
I agree w/ Frizzle and Chase - don't waste money changing to a Z06 cam - not enough improvement to justify the work involved -
Old Feb 28, 2007 | 09:26 AM
niemann_mark
Thanks for the info. I cant really recall all the cam info..ie lift/ duration..ect So if yall have any suggestions on a cam that would do better, without going crazy, I would really appreciate it. I will consider getting some heards soon as well. I just didnt want it to be to much louder, it is a little loud with the vert already.
Old Feb 28, 2007 | 09:46 AM
myk7's Avatar
myk7
These may help you make a decision
LS1 Lift Duration LSA Timing
97-99 .472/.479 199/207 117 121/113
2000 .500/.500 198/209 115.5 119/112
01-03 .467/.479 196/207 116 115/117
LS6 Lift Duration LSA Timing
2001 .525/.535 204/211 116 118/114
02-03 .555/.551 204/218 117.5 120/115
Old Feb 28, 2007 | 10:47 AM
chaase's Avatar
chaase
St. Jude Donor '12
Something like one of these from comp cams would do you well. They even make one in between
Camshaft Specification Table
Part Number 54-414-11
Engine 1997-Present General Motors
4.8ltr-6ltr
Gen III/LS1/LS2/LS6,
8cyl.
Grind Number LS1 XR269HR-14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.525 0.532
Duration At 0.006 Tappet Lift 269 273
Valve Timing At 0.006
Open Close
Intake 23 66
Exhaust 73 20
These Specs Are For The Cam Installed At 112 Intake CL
Intake Exhaust
Duration At 0.05 216 220
Lobe Lift 0.309 0.313
Lobe Separation 114
Recommended Valve Springs 941-16
Part Number 54-426-11
4.8ltr-6ltr
8cyl.
Grind Number XR275HR
Description
Intake Exhaust
Valve Adjustment 1 1
Gross Valve Lift 0.566 0.568
Duration At 0.006 Tappet Lift 275 277
Open Close
Intake 28 68
Exhaust 73 25
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 222 224
Lobe Lift 0.333 0.334
Lobe Separation 112
Recommended Valve Springs 26918-16
To Slight performance upgrade questions.
