Odyssey 925 Install (pics)
Old Feb 28, 2007 | 06:57 PM
Last C5's Avatar
Last C5
Default Odyssey 925 Install (pics)
Some of you were wondering what an Odyssey 925 looks like installed on its side with the Odyssey aluminum bracket. Here it is.
Last C5
Old Feb 28, 2007 | 07:14 PM
see5's Avatar
see5
Last C5
Did you by chance do a relative wt?
Old Feb 28, 2007 | 07:33 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
that little thing starts your vette ?????????????????????
Old Feb 28, 2007 | 08:05 PM
Last C5's Avatar
Last C5
Actually the next size down will also start the car fine too. The weight of the 925 is 26 lbs.
Old Feb 28, 2007 | 09:16 PM
TopFuelTim's Avatar
TopFuelTim
Default Cute!
That little thing starts the car? Next question; how much is it?
Tim Glover
Old Feb 28, 2007 | 09:22 PM
SLPRC5's Avatar
SLPRC5
Tim Glover
Not polite to ask but and where can you get them also does it come with everything shown in your picture?
Thanks..
SLPRC5
Old Feb 28, 2007 | 09:26 PM
Sully1882's Avatar
Sully1882
Default googled it and found this
here's a link I found...
http://www.batteryweb.com/odyssey.cfm
hth,
sully
Old Mar 1, 2007 | 03:38 AM
Last C5's Avatar
Last C5
I got both the battery ($154) and the side mount hold down ($39) from Batteries Plus, I believe they're a national chain.
Old Mar 1, 2007 | 08:58 AM
JEEP/C5's Avatar
JEEP/C5
How long have you had your 925? Did you have to drill to make the side mount bracket work? Is your ride a DD? Mine will sit for 3 to 5 weeks at a time from Dec to Feb. and im concerned the battery will not have enough reserve. I dont use a trickle charger right now but I dont have a problem starting her with the GM battery. Thanks for the pics, the 925 looks pretty good! Slap a c5 emblem on the bracket and your good to go!
Old Mar 1, 2007 | 08:59 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
DD approved?
Old Mar 1, 2007 | 09:21 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
mine runs off about 30 "D" batteries
Old Mar 1, 2007 | 10:04 AM
Oldvetter's Avatar
Oldvetter
Very interesting, will have to look into when I next need a battery. But with my Exide AGM, that could be quite a while !
Old Mar 1, 2007 | 01:06 PM
Last C5's Avatar
Last C5
Jeep/C5
I've only had the battery about a month and it's only sat for about a week at a time. The Z is not my DD, it's a track car/sunnyday moral builder/etc. Drilling - yes, I drilled 4 ea 3/8" holes in the battery tray and fixed captured nuts with flanges with stainless pop rivets (the same process used on the factory hold down captured nut) Nothing very difficult and I can go back to stock in minutes. I left you a tongue in cheek response on the "battery weight" thread.
Last C5
Old Mar 1, 2007 | 01:36 PM
gorillavet's Avatar
gorillavet
Another option. Don't worry about the racing comments. Use everyday in a daily driver without any issues.
http://performance.accuratetechnolog...49e1775194461e
Old Mar 1, 2007 | 03:16 PM
JEEP/C5's Avatar
JEEP/C5
Gorillavet, how long have you had yours? You have the 680 model right? What is the longest you let your ride sit without starting?
Thanks for the info guys. I will make my decision soon. My old one is GM (not original) but is almost 5 year old and the little "green eye" is black. I don’t know if that means anything but I don’t want to risk the dreaded acid leak either.
Old Mar 1, 2007 | 08:16 PM
MadMaxZ06's Avatar
MadMaxZ06
I couldn't have said it better myself! I've had my Odyssey Model 680 for about 2 years and NO problems. The only reason I went with Odyssey was to get a battery that wouldn't leak (evidently some C5's OEM batteries leaked) The fact that it's much lighter and smaller is icing on the cake. It is not my Daily Driver, and I've let it sit for just over 2 weeks with no ill effects. If you should have any technical questions on the product, I recommend speaking with Bruce Essig from Odyssey at (660) 429-7506. Super friendly and KNOWLEDGEABLE!
- Max
Old Mar 1, 2007 | 09:06 PM
TopFuelTim's Avatar
TopFuelTim
Default Thank you for the info
This is really neat. My battery is OK now, but being several years old, I have already wondered what to put in next. Optimas seem too iffy, getting both good and bad reviews here. I'm definitely going to consider this for the next go round.
Tim Glover
Old Mar 1, 2007 | 09:36 PM
2000BSME's Avatar
2000BSME
a friend of mine uses an even smaller battery for his M3, and it has left him stranded twice in about as many years. It was a very small battery though. Cold weather starting may be a slight issue in some circumstances.
To Odyssey 925 Install (pics)
