Got a header question?
Old Mar 3, 2007 | 03:36 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default Got a header question?
can some one help me, and try to explain the differences between
stainless and ceramic ? What are the Pros and Cons of the two. Does one work better then the other? I want to put some on a 98 with a supercharger, I have looked at texas speed and looked at the ebay headers!! jus the two i have looked at and money is a factor !!!
thanks jay
Old Mar 3, 2007 | 11:32 PM
jeanlucpicard's Avatar
jeanlucpicard
Jay,
Most C5 headers are made out of stainless steel these days which is why a set of long tubes will set you back between $900 and $1500 depending on whose you buy. The ceramic coating is applied to the header to keep engine bay heat down. The coating is maybe .020" thick or thereabouts and is worth the usual added fee of around $200 or so.
I would stay away from carbon steel headers since they tend to corrode and most Corvette after market exhaust systems are stainless steel anyway.
Old Mar 3, 2007 | 11:52 PM
tellefan's Avatar
tellefan
If you buy the mild steel coated headers they can still rust. It only takes a small nick, or scratch to set it off. David
Old Mar 4, 2007 | 09:16 AM
davidfarmer's Avatar
davidfarmer
Definitely get SS, ceramic optional. I've had non-SS header crack in a really short period of time
To Got a header question?
