Ruined Textralia!
Old Mar 3, 2007 | 08:42 PM
97Rob's Avatar
97Rob
Default Ruined Textralia!
Has any one ever ruined a Textralia clutch by using an adjustable master cylinder. I have a Tex and had an Adjustable master, and am having mild shifting problems at high RPMS. Then I heard you are not supposed to use the adjustable m/c w/ a Tex. clutch. Called the Tex. rep and he confirmed this for me. Any one else experience this?
Old Mar 3, 2007 | 09:51 PM
FRCTony's Avatar
FRCTony
I'm having a hard time seeing how it could ruin the clutch...
Old Mar 3, 2007 | 10:03 PM
97Rob's Avatar
97Rob
The adjustable m/c has more pressure concerning hydraulics, which can cause the pressure plate to over travel bending the fingers.
Old Mar 3, 2007 | 10:19 PM
FRCTony's Avatar
FRCTony
I'm not buying that. It seems they would be bankrupt in a hurry if true.
It should be easy enough to confirm or deny on autopsy...
Seems like you've really had a rough time recently.
I feel for ya bro.
Old Mar 3, 2007 | 10:57 PM
97Rob's Avatar
97Rob
I feel for ya bro.
Yeah, its been a long rd, but its almost over. Looking forward to some track time real soon.
Old Mar 3, 2007 | 11:43 PM
chuckster's Avatar
chuckster
The Adjustable Master simply adjusts the rod for pedal height. I guess if the rod was adjusted out too far it could conceivably push the pressure plate way to far.. You can check it by pushing the pedal to the floor while it's running and in gear.. Then see how far you lift the pedal before it engages...
Old Mar 3, 2007 | 11:53 PM
onewheeldvl83's Avatar
onewheeldvl83
On a hydraulic clutch there is a check ball in the master try opening the bleeder screw and see if you have pressure in there because the hydraulic pressure can slowly build up and not release all the way causing the clutch to stay engaged especially if you tried adjusting the free play on the pedal.
Old Mar 4, 2007 | 01:03 AM
97Rob's Avatar
97Rob
We installed a new stock m/c.
Chuckster, if I understand correctly the adjustable pushes more volume which hyper extends the fingers on the pressure plate. If any one should know it would be Jared Cunningham the rep. from Textralia. He said using this master w/ this clutch would ruin it. I think he is going to try an get a new clutch out to me under warranty, so he not just trying to sell me another clutch!
Thanks a lot for the action on the thread guys! I enjoy trouble shooting and discussing these things.
Old Mar 4, 2007 | 08:42 AM
willyfastz's Avatar
willyfastz
Well we've had plenty to talk about then.
Old Mar 4, 2007 | 09:06 AM
97Rob's Avatar
97Rob
If they only knew the conversations we've had. I've kept most of it on the down low. The other was to depressing to talk about in public. This seems almost trivial compared to my previous problems.
Old Mar 4, 2007 | 09:11 AM
blazeone's Avatar
blazeone
Nice post title.
Seems like Tex is fixing your problem.
97Rob [quote]Just talked w/ Jared from textralia and he said that I probably ruined the clutch by using an adjustable m/c. He said to call back Monday, and he would see about taking care of the clutch under warranty. This will be my second dealing w/ this guy on a clutch warranty. This company has to have the best customer services I've experienced.
Old Mar 4, 2007 | 12:50 PM
chuckster's Avatar
chuckster
You did not specify if the adjustable was an after market... Only way to increase the fluid volume is to increase the Bore size have the shaft incorrectly adjusted
The ones I have seen are essentially Stock Masters with a threaded shaft.. if it's adjusted so far that the master is already starting to engage the clutch I can see it happening..
This is the exact reason I believe so many stock clutches have the sticky issue.. They are over extending the pressure plate springs
Normally you hit the floor before you bottom out the Master..
Old Mar 4, 2007 | 02:22 PM
97Rob's Avatar
97Rob
Pretty sure its a Mcleod. I will keep it updated. Its always nice to figure these things out.
Old Apr 11, 2007 | 10:53 AM
AlwaysInBoost's Avatar
AlwaysInBoost
any updates for us?
Old Apr 11, 2007 | 11:11 AM
MotleyDrew's Avatar
MotleyDrew
Old Apr 11, 2007 | 11:24 AM
Billdog350's Avatar
Billdog350
I have heard to stay away from the Mcleod adjustable masters for just about any LS1 single disk clutch for the reasons posted above (over extending the pressure plate)
Why not just throw an OEM Ls6 master in there and call it a day? I went with the LS6 master and slave for my Tex and it seems to be working properly so far.
Old Apr 11, 2007 | 12:57 PM
chuckster's Avatar
chuckster
Sorry to hear of your troubles
What ruined the clutch is the fact that the Master was NOT ADJUSTED properly.. Plain and simple.. If it was adjusted correctly.. The pedal would bottom out on the firewall well before you overextended the fingers. That is the entire point of having an adjustable master.
It's sort of like saying my car went too fast because the gas pedal can go all the way to the floor..
Not trying to be a jerk, just trying to shed some light here.. some people on this forum like to turn everything into a Witch hunt.
Sounds like the Tex Rep should have known better than to simply blame it on the master with no explaination.
To Ruined Textralia!
Old Apr 11, 2007 | 01:55 PM
AlwaysInBoost
This entire thread is about how an Adjustable master ruined the Clutch..
I don't believe the OP stated anywhere in this thread yet that the adjustable M/C was the culprit and swapping it out for an OEM unit fixed the problem.
Old Apr 11, 2007 | 02:09 PM
chuckster's Avatar
chuckster
You are right I should not have said that.. I will edit it.. The point being that the TEX rep said it and then the last post about staying away from the AdJ Master because it over extends..
Again.. Only because it was misadjusted to begin with..
I simply wanted to keep the Cause and and the Symptom factual..
Old Apr 11, 2007 | 03:21 PM
IFLUBYU's Avatar
IFLUBYU
Had the same issue. At the time mine was installed Textrailia was non-commitant about the adj master cyl (mine was mcleod), had shifting problems for about a year (kept me off the track, I was pissed), after trying multiple adjustments, I had it replaced with a LS6 master, now its all good. Squeels a bit from a stop, but no big deal.
I doubt your clutch is ruined, but let us know how it works out.
Good Luck!
