Help, 2001 whistling intake manifold?
Old Oct 9, 2001 | 06:59 PM
Anderson's Avatar
Anderson
Default Help, 2001 whistling intake manifold?
I have a 2001 coupe auto.
I can hear a whistle come from the engine compartment when idling.
I have read a few posts about the intake manifold problem for the 2001.
Has anybody brought their 2001 to a dealer and have them replace it with a 2002 intake manifold? And if so, did this fix your problem? Also, do you know the TSB# (technical survice bulletin). Is it possible to look up all the TSBs myself and find it?
I just spoke with Bill Jacobs in Joiet IL and they don't know what I am talking about. Can I just force them to replace it?
Please help.
Thanks.
Old Oct 9, 2001 | 07:35 PM
C5TECH's Avatar
C5TECH
Default Re: Help, 2001 whistling intake manifold? (Anderson)
The manifold whistle only occurs at part throttle 1800-2500 RPM. There is an idle whine at cold start from the smog pump which is normal.
