Noisey Hurst Short Shifter
Old Mar 5, 2007 | 11:06 PM
James k Matheson's Avatar
James k Matheson
Default Noisey Hurst Short Shifter
I have an 01 C5 and I installed a HURST short throw shifter . I really like the way it shifts but it make a rattling noise coming from the drive train when under load. Is there a way to isolate and iliminate this vibration from the transmission and drive line?
Thanks for any help on how to isolate this vibration.
Jim Matheson
Old Mar 6, 2007 | 03:19 PM
C5 ChemE's Avatar
C5 ChemE
Same thing here. Most shifters for the C5 do it. If you do a search for this, you'll find MANY people with the same problem. Only solution I've heard of is buying a heavy **** or doing the "tennis ball mod"
Old Mar 6, 2007 | 03:23 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Jim Matheson
all i did was wrap alot of teflon tape on the shifter **** threads..enough to make it hard to twist the **** back on.....now i have silence!
Old Mar 6, 2007 | 03:31 PM
bb609's Avatar
bb609
I cut the metal ring off the bottom of the shifter gasket and mounted it normally. I have a Hurst shift ball. Between the two, I have zero noise or vibration.
Old Mar 6, 2007 | 04:57 PM
robert123's Avatar
robert123
typical hurst shifter problem.
Old Mar 6, 2007 | 05:32 PM
keith954's Avatar
keith954
St. Jude Donor '06, '13
is the rubber boot inverted or actually cut snug around the base of it? mine was super noisy untill i cut the boot around it
Old Mar 6, 2007 | 05:37 PM
hotwheels57's Avatar
hotwheels57
There's been past discussions about using the smallest HURST generic shifter boot to help reduce the noise level.
Old Mar 6, 2007 | 05:55 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
this has worked for many
http://www.z06vette.com/forums/showt...ht=quiet+hurst
Old Mar 6, 2007 | 06:20 PM
hotwheels57
I think someone had a post not long ago that used one of these generic boots to reduce the noise. Unfortunately, since HURST and B&M have now merged, there respective websites and (new combined website) are not accessible...
Old Mar 6, 2007 | 07:14 PM
FUN LS1's Avatar
FUN LS1
anyone get the OEM **** to work with a short throw mod?
Old Mar 6, 2007 | 09:18 PM
keith954's Avatar
keith954
To Noisey Hurst Short Shifter
