SS Brake Lines
Old Mar 7, 2007 | 10:46 PM
vette dan's Avatar
vette dan
Vette Dan
Default SS Brake Lines
Just got new ss Brake lines from LAPD.
What do you torque each end too??
Will call them in AM.
TXS
Old Mar 7, 2007 | 10:50 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
I just ordered a set too. No install paperwork with them with specs? If nobody responds please post back here what they tell you.
Old Mar 7, 2007 | 10:51 PM
jeanlucpicard's Avatar
jeanlucpicard
I used my 10mm wrench and tightened until snug. That was about 4 years and 50,000 miles ago and haven't had a leak yet.
Too much is made out of torquing everything. Some items just call for nutting it down and moving on.
Old Mar 7, 2007 | 11:12 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
I actually just emailed them earlier today on this exact issue. Heres what the told me:
"We don’t have a set of directions for the SS lines. The only advice I could give you is that the longer lines go in the rear. You install them in a “S” bend shape and when tightening them, get them snug and then give it one more push.
Hope that helps."
Not the answer i was looking for but oh well...
Old Mar 8, 2007 | 07:24 AM
IM QUIKR's Avatar
IM QUIKR
If they have brass banjo bolts like Goodridge has then 20-23#s
If they reuse the factory steel bolts then 30#
Old Mar 8, 2007 | 08:36 AM
vette dan's Avatar
vette dan
Vette Dan
I wondered about length also. So we now know at least part of the story.
Old Mar 8, 2007 | 08:43 AM
IM QUIKR's Avatar
IM QUIKR
short up front
long in the back
Make sure they don't rub before you torque down the flex to hard line. Don't forget to cap the hard lines, you don't want air working its way to the ABS. This is a good time to install "speed bleeder" bleed valves.
Old Mar 8, 2007 | 01:53 PM
bomax's Avatar
bomax
13lb fts on the hard line side, and the banjo bolt torque specs vary. StopTech recommends 14ft lbs which is what I used and have not had any leaks.
Old Mar 8, 2007 | 03:54 PM
IM QUIKR's Avatar
IM QUIKR
Stop tech may have a smaller bolt or softer aluminum calipers. 13#s sounds too light IMO. What brand lines did you buy? and what hardware are you using to reinstall it?
Old Mar 8, 2007 | 03:59 PM
B-ras's Avatar
B-ras
TXS
I'm glad you asked this question, cuz I was about to email Shawn to find out for myself. After reading that other thread, I know I'm not going to 37lb. ft.
Stealthy4- I am a bit troubled by that response. If the company sells something, they should be able to answer a simple install question.
Old Mar 8, 2007 | 04:29 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
13 ft-lbs.
Shawn
Old Mar 8, 2007 | 05:03 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Well it looks like its 13 ft.lb but heres the email directly from my inbox:
Old Mar 8, 2007 | 05:30 PM
B-ras's Avatar
B-ras
I never doubted ya.
BTW- Did you correctly guess what's in Rian Johnson's pants?
Old Mar 8, 2007 | 06:02 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
There are two of us here named Shawn so that email you received was from the other Shawn. I posted this already, but I recommend 13 ft.-lbs. which was already posted by someone else. Again, sorry about that, but no aftermarket lines come with install instructions.
Shawn
Old Mar 8, 2007 | 06:15 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Shawn
No, it cool...i'm glad you were able to chime in for us. Its cool that we know the answer now!
I thought maybe since you work on so many vettes, you might have created your own directions...and i wanted them...lol
BTW - its a secret whats in my pants...
Old Mar 8, 2007 | 06:28 PM
B-ras's Avatar
B-ras
Shawn
Thanks for stepping in to clear this up, Shawn1. Or are you Shawn2?
Old Mar 8, 2007 | 06:30 PM
B-ras's Avatar
B-ras
Oh sheit, guess if I'da looked at your profile I'da realized that was you.
Old Mar 8, 2007 | 08:54 PM
2000BSME's Avatar
2000BSME
Install speed bleeders at the same time.
Sounds imprecise, but really, you have to be a knuckle dragging moron to strip 'em out, and if you don't get 'em tight enough, well then you are a knuckle dragging moron also. Use the new washers that come with them, and be prepared to get 'service active handling' warnings intermittently, as I've heard that is common with any brand of s.s. lines. They say if you add a ground along side the line, you can avoid that, but I haven't verified that yet.
To SS Brake Lines
