Big Nasty Sounding Cam
Old Mar 9, 2007 | 01:41 AM
mi97vette's Avatar
mi97vette
Default Big Nasty Sounding Cam
Okay what is the badest sounding cam you can stuff into a stock 1997 ls1, and if I change the heads, What are your opinions???
Going to be building a LSX motor when released but it wont be in the car this year...
Old Mar 9, 2007 | 03:55 PM
dazman's Avatar
dazman
go to ls1tech and look over there for the meanest sounding cam thread... its like 15 pages long
Old Mar 9, 2007 | 04:19 PM
Tuner@Straightline's Avatar
Tuner@Straightline
G5X3/X4, we use them all the time.
Old Mar 9, 2007 | 05:11 PM
Z28TOZO6's Avatar
Z28TOZO6
straightline, can you tune them with good street manners?
Old Mar 9, 2007 | 08:59 PM
Tuner@Straightline
Yes, we use the cam more than any other one. My tuning process is 3-4 hours, not just a few rips on the dyno. I had it in my 02 Z28 for a year and drove the car year round until the tranny started to go, and it shattered 6 valve springs bouncing off the rev limiter. I had no driving issues, and the cold starts were good as well.
Old Mar 9, 2007 | 09:04 PM
Z28TOZO6's Avatar
Z28TOZO6
what springs?
Old Mar 10, 2007 | 09:49 AM
Tuner@Straightline
For springs, nothing less than Patriot Golds. If you want better than that, then go with Comp Cam 26921's.
Old Mar 10, 2007 | 10:44 AM
happa's Avatar
happa
I just put in my G5X4 and had it street tuned, sounds pretty nasty. You can go to www.ls1sounds.com too to here some cams.
Old Mar 10, 2007 | 02:21 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I have the g5x3 with the 921 springs and have no problems at all. Its nasty sounding too !! Its my daily driver and is tuned very well by Sean at LGM.
Chris
Old Mar 10, 2007 | 03:25 PM
EBMR02Z's Avatar
EBMR02Z
Tuner,
Is it true that you have to flycut the pistons with the G5x3? I keep hearing it both ways.
Old Mar 10, 2007 | 04:36 PM
happa's Avatar
happa
Originally Posted by EBMR02Z
Tuner,
No you dont have to flycut
Old Mar 11, 2007 | 07:29 AM
200MPH's Avatar
200MPH
My comp custom grind sounds pretty nasty. 236/244-601/610-110lsa
Old Mar 11, 2007 | 06:33 PM
pdd000's Avatar
pdd000
the more overlap the nasty'r the sound
Old Mar 12, 2007 | 01:09 AM
rustyguns's Avatar
rustyguns
what rpm do you idle at?
Old Mar 12, 2007 | 01:12 AM
rustyguns's Avatar
rustyguns
COMP CAM # 954 springs any good? they work with a g5x3?
Old Mar 12, 2007 | 03:02 AM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
T-Rex is the nastiest sounding cam I have heard.
Old Mar 12, 2007 | 01:12 PM
2003Torch's Avatar
2003Torch
If you do the cam on a 114 LSA you will not have to cut. Anything lower and you will have to flycut. As a rule though you should check PTV clearance before firing it up even with a g5x3 on a 114.
Mark
To Big Nasty Sounding Cam
Old Mar 12, 2007 | 03:13 PM
Tuner@Straightline
Here's a video of a custom ground cam at idle set up we did this weekend, a little different than the G5x3/4.
http://s135.photobucket.com/albums/...nt=MOV00350.flv
Old Mar 12, 2007 | 03:23 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Second video - G5X4, PRC springs, stock LS1 heads, no flycutting
Old Mar 12, 2007 | 03:52 PM
402Sam's Avatar
402Sam
I got a 257/266 644/622 on a 110 lsa goin into my car this week. As soon as I get her all finished up I will post some videos....
