Goodyear EMT's
Old Oct 10, 2001 | 01:57 PM
NCOMNC5's Avatar
NCOMNC5
Default Goodyear EMT's
Do runflats have a inner-tube or bladder inside of tire. If not how are you able to drive on it for 50 miles as the owners manual states. :confused: :confused: :confused:
[Modified by NCOMNC5, 11:58 AM 10/10/2001]
Old Oct 10, 2001 | 02:45 PM
rrussell's Avatar
rrussell
Default Re: Goodyear EMT's (NCOMNC5)
No bladder, just really stiff heavy side walls on the tire.
Old Oct 10, 2001 | 03:18 PM
NCOMNC5's Avatar
NCOMNC5
Default Re: Goodyear EMT's (rrussell)
thanks russell, appreciate the feedback :D :D
Old Oct 10, 2001 | 04:59 PM
rocketrider2's Avatar
rocketrider2
I thought the Goodyear EMT's give you 200 miles not 50, am I wrong here?
Old Oct 10, 2001 | 05:09 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Goodyear EMT's have stiff rubber inserts in the sidewall.
[Modified by kewlbrz, 3:09 PM 10/10/2001]
RedLandRocket's Avatar
RedLandRocket
Default Re: Goodyear EMT's (rocketrider2)
250 miles at a maximum speed of 50mph.
If you kept then cool, you could probably drive them forever with no air, just not very fast.
Old Oct 10, 2001 | 09:12 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: Goodyear EMT's (RedLandRocket)
I believe the "50 miles at 50 mph" limit is to prevent further damage to the tire, so it will be repairable if the original puncture was not too bad. The 250 (or is it 200?) mile limit is about how far you could go if you were willing to trash the tire.
Let's see, if I can safely go 50 miles at 50 mph, does that mean I can go 250 miles at 1 mph? Or 1 mile at 250 mph? Enquiring minds want to know.....
Old Oct 10, 2001 | 10:08 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You read the manuel wrong... You can drive on a flat EMT , ( Not a Firestone run flat) for 200 miles at 50 miles an hour...
If you have Firestone Run Flats you can only drive on it for 50 miles..
Yes the sidewalls are very strong... no bladder or inner tube.. there is also a complex fiber matrix in the side wall to keep them stong and get you home safe.. even with no air .. 200 miles... at 50 mph...
Old Oct 10, 2001 | 10:31 PM
Gearhead Jim
St. Jude Donor '13
Default Re: Goodyear EMT's (Evil-Twin)
Here's a quote from my 2001 Chevrolet Corvette Owner's Manual, page 6-41:
"If you drive on a deflated EMT for 50 miles or less and at speeds of 55 mph or less, there is a good chance that the tire can be repaired. The tire can operate effectively with no air pressure for up to 200 miles at speeds up to 55 mph, but the tire would then have to be replaced."
From the "Eagle F1-GS Extended Mobility Tire- Owner's Manual and Limited Warranty", first page:
"Although the Eagle F1-GS EMT has been designed to give up to 200 miles of service at suatained speeds of up to 55 mph at low or zero air pressure, after such extreme usage the tire would have to be replaced." ....."and if you drive less than 50 miles, there is a good chance that the tire will be repairable..."
Old Oct 11, 2001 | 12:56 AM
Evil-Twin's Avatar
Evil-Twin
Default Re: Goodyear EMT's (Gearhead Jim)
Like I said you can safely drive a GY EMT at 50 MPH for 200 miles...
Old Oct 11, 2001 | 01:25 AM
ScreaminDemon's Avatar
ScreaminDemon
Ofcourse, as we all know, if the flat is on the front you could do a wheelie stand all the way home and not worry about your flat tire! :lol: :smash:
Old Oct 11, 2001 | 12:55 PM
Evil-Twin's Avatar
Evil-Twin
Default Re: Goodyear EMT's (ScreaminDemon)
<-------Not sure what this means....
The simple fact is.. you can drive 200 miles at 50 mph... with no air in the tire.. or all the tires.. and from my research you do not even know you have a flat tire expect for the display. There have been numerous post of people having flats and gashes in their EMT's and got home safely.. road to the tire store the next day without missing abeat.. I also saw a guy do 3000 dollars damage to his C5 by Not having run flats....
Old Oct 11, 2001 | 10:50 PM
ScreaminDemon
Wheelie stand- Front end of car lifts completely off the ground at WOT. :jester
Old Oct 12, 2001 | 12:21 AM
Sir Sel's Avatar
Sir Sel
Got a flat last weekend and was able to drive 30 miles home no problem. It makes quite a bit of noise but works great and the dic indicated keep speed under 55. :cheers:
To Goodyear EMT's
