Drag radial recommendations
Old Mar 9, 2007 | 07:33 PM
lucky131969's Avatar
lucky131969
Default Drag radial recommendations
Just finishing up my A&A vortech install. I plan on roasting the Kumhos off the rear, and then getting a good set of drag radials. What is a good pair to use on stock rims? How do they perform on the street?
Thanks in advance.
Old Mar 9, 2007 | 08:20 PM
myk7's Avatar
myk7
I sure wish Mickey Thompson would come out with 18" ET Streets. I'm going to go with M/T 275/40/17. I hear BFGs are ok if you get the air pressure exactly right.
Old Mar 9, 2007 | 08:42 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Only ones you can really use on the street are the Nittos. I used to run the 335s. The BFGs and M/Ts are stickier, but only last a fraction of the time and are no good in the rain.
To Drag radial recommendations
