Do I really need a programer????
Old Mar 10, 2007 | 06:12 AM
Gohard777's Avatar
Gohard777
Default Do I really need a programer????
OK, I admit that I'm old school, and, back then we didn't ask for help. I'm trying to go hi-tech, even got a Superchips for my Denali for when I ran my 22's. Now, I hear that I need a programer because I'm going to go to 373 gears and a torque coverter, and somewhere, I've read that you have to change the shift points? Is this true and could you please make an old (older) guy understand why?? To me, if a car shifts at 6000RPM's and you put 373's from the 315's, won't it still shift at 6000 RPM's? And, is there any other reason to get the programer? I want one, I just want to know if I need one and why....Thanks guys....bob.
Old Mar 10, 2007 | 09:47 AM
robert123's Avatar
robert123
true, you will need to get a programmer so your speedo will not be off. it may help with your shift points also. If you go into the tuner section a man called Charlie is tunning pcms for 100.00. He just did mine. If you pm him he will answer your questions.
Old Mar 10, 2007 | 06:04 PM
Gohard777's Avatar
Gohard777
I thought that somebody on here said that you don't have to do the speedo because of how it works. I had to do my Denali's speedo when I switched tires........bob.
Old Mar 10, 2007 | 06:08 PM
Mike Mercury's Avatar
Mike Mercury
incorrect
there's a lot of reasons to reprog after a rear axle swap in a C5 A4, but speedo calibration is not one of them. There is no speedo error on any C5 when changing rear axle ratio.
Old Mar 12, 2007 | 01:04 AM
Gohard777's Avatar
Gohard777
Default Programmer????
give it to me straight Mike, I can take it. I don't know if I can pay for it though...........bob.
Old Mar 12, 2007 | 07:09 PM
gojo's Avatar
gojo
As Mike said, the speedometer is not effected for C5's. You will need to reprogram, though. Your example of 6000rpm's is with regard to WOT. Usually WOT shifts are controlled by RPM's. However, the part throttle shifts are based on MPH and require programming. Also, the PCM reads the extra RPM's vs trans revolutions as slipping. It will throw codes and go into safe mode. Safe mode shifts very hard in order to protect the trans from further slippage damage. You will not like it. Correct programming eliminates this problem in most cases, but sometimes high stall converters require changing the slip test parameters. It's all worth it. The car will come to life.
Old Mar 25, 2007 | 04:40 AM
Gohard777's Avatar
Gohard777
Default Need more input.......thanks...
this was from Gojo...thanks....
will the Predator programmer do this?? I'm still kinda confused on how to adjust part throttle shifting. On the Superchips, (for my Denali with 22's) I adjusted for firmer or smoother shifts and at what RPM's, when the 373's and 3200 stall converter (in Vette) is installed, what do I do next and will the Predator do it, my friend suggested this from a shop that he works at but he does motors and doesn't know why they prefer to use the Predator... any tuners, vendors or anybody use this stuff that can help??? thanks in advance....bob.
Old Mar 25, 2007 | 05:57 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 25, 2007 | 02:22 PM
Gohard777's Avatar
Gohard777
OK... don't know what this stuff is just yet, torque management and slip test parameters but, will the Predator programmer do this? please guys, more info....thanks ....bob....(and I'll try to let you Z06 guys know when to trade up to the Z08!....coming soon.)
Old Mar 25, 2007 | 03:11 PM
Mike Mercury
yes. The Predator will alter the "TCC Slip Table" so that the PCM won't throw a P1870 error code.
The A4 PCM WOT shifts are commanded when two parameters are met... MPH and RPM. When you change rear axle ratio, the MPH @ 6000rpm will be lowered. The PCM won't command a WOT shift until both the MPH figure and RPM figure are reached. It it's attempt to reach ther MPH value, the engine continues to accelerate until you hit the rev limiter (although the RPM setting had been reached, the MPH figure hadn't - yet).
It's all (or mostly) here:
1. Did I have to get my PCM reprogrammed for the new rear axle ratio?
http://mikemercury.home.att.net/342.htm
Old Mar 26, 2007 | 01:46 AM
Gohard777's Avatar
Gohard777
thanks Mike, you're always helpful...bob.
Old Mar 26, 2007 | 10:03 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I thought that somebody on here said that you don't have to do the speedo because of how it works. .
true, but only 6-speeds i believe
Old Mar 26, 2007 | 10:17 AM
Mike Mercury
incorrect.
To Do I really need a programer????
