I have a line lock I want to install this weekend and I have nu instructions. Question; does it go between the MC and the distribution block or the distribution block and the ABS unit? I'm assuming the layter and that it would replace the line nearer the firwall to the top right line on the ABS unit. Cottect?
PS ignore the typeing P had eve surgery and my fingers and eyes seem to no longer have a direct connection.
It sounds like you have a 99 or 2000 corvette. They had a proportioning valve between the MC and the ABS. If that is the case then the line lock goes after the proportioning valve. So it goes between the proprtioning valve and the ABS.
The other years had nothing between the MC and the ABS.
on our 89' we had to go between the abs and the front caliper, 1 solenoid on each side right at the fitting where the hard line mated to the flexible line. you just want to lock up the front calipers and leave the rest of the brake system open.
