methanol???
Old Mar 11, 2007 | 01:47 AM
cracker Bear's Avatar
cracker Bear
Default methanol???
Is this for Nitrous/turbo/supercharged cars only.... or could a normaly asperated engine see significant gains from this..???? I hope some one here knows cuz i have spent way too much time one the internet reserching and have come up empty handed.. alls it talks about it octane, cooling with turbos and no where about a non charged car
Old Mar 11, 2007 | 03:38 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
You could use it, but it won't help.
Methanol is used as an anti detonation tool among other things. Some people will argue with me, but there are no gains to be had using methanol over gasoline, in fact you may see just the opposite.
Most people running FI use methanol as:
1. an alternitive fuel when there pump/injectors are maxed out
2. Anti detonation tool, since Methonal is high octane, it is less flamable
3. To cool Intake temps due to the FI creating more heat.
It would not be beneficial to run Meth on a NA setup.
Old Mar 11, 2007 | 05:08 AM
rustyguns's Avatar
rustyguns
WELL....FROM WHAT I HAVE READ. IF YOU ARE RUNNING HIGH COMPRESSION, WITHOUT BLOWERS OR SPRAY, YOU WILL BENEFIT FROM ALKY SETUP
Old Mar 12, 2007 | 02:13 AM
Mr. Big's Avatar
Mr. Big
I would love to see proof of that. I don't think there is anyway you pick up power just by adding Meth, everything else being equal.
Old Mar 12, 2007 | 12:29 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
The purpose of Methanol is to stop detonation on extremely high compression engines. If you don't have a supercharged or turbocharged 15:1 engine, or something like that, there is absolutely no point.
Methanol is a slower burning fuel, and without that high compression, you'll just end up with carbon build up on your pistons and so on, as it wouldn't efficiently burn all of it. Same reason you shouldn't run 92 octane in your Geo Metro...
Old Mar 12, 2007 | 12:56 PM
2003Torch's Avatar
2003Torch
Simply amazing! Do more research. There are many benefits to running a water/meth mixture applicable to NA also.
Mark
Old Mar 12, 2007 | 01:06 PM
Mr. Big's Avatar
Mr. Big
The only possible benifit i can see to running Meth on an NA motor would be lower intake temps. But the offset would be a decrease in power. Again, if someone will show me proof, I'll shut up.
DannyG's Avatar
DannyG
St. Jude Donor '10
Mark
If you run water/meth injection... yes... not if you just run straight methanol in the tank...
To methanol???
