Den's roadster
Old Mar 11, 2007 | 03:39 PM
maysdens's Avatar
maysdens
Default Den's roadster
Does anyone know how much the standard 97-99 Vette wheel weigh? I'm getting ready to replace my existing wheels and want to make sure the new ones are no heavier than the ones I'm taking off.
Old Mar 11, 2007 | 07:11 PM
BanditDude's Avatar
BanditDude
Here's some weights from the "sticky" at the top of the C5 General section. Good luck!
Wheels
19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon - Src
22 lbs, front; 29 lbs, rear - 97-99 OEM wagon - Src
17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium - Src
17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium - Src
18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish - Src
17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps - Src
16 lbs, front; 20 lbs, rear - 01 OEM standard high polish - Src
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged - Src
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun - Src, Src
24 lbs, 18x10.5 - 00+ repro high polish - Src
28 lbs, front; 32 lbs, rear - Z06 chrome repro - Src
23 lbs, front; 26 lbs, rear - Z06 chrome repro - Src
23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished - Src
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear - PWO - Src
22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center - Src
27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center - Src
24/25 lbs - Z07 wheel weight, front - Src
28 lbs - Z07 wheel weight, rear - Src
Old Mar 11, 2007 | 07:37 PM
65GGvert's Avatar
65GGvert
Why the big difference in the same wheel? For instance, the first two lines seem to be the same wheel, but the rear is almost 8 lbs heavier on the second line. What am I missing?
To Den's roadster
