B0-rfa No Comm.
I figured I'd look for loose connections and there appears to be a module located above the left rear insulator panel in the hatch area. The manual says to remove the one retainer but I can't figure out how to remove the panel. Any hints on that or anything else I might check?
SDM B1001 H
PCM P1571 H
LDCM B2284 H. B2262 H. U1064 H. U1096 H
RDCM B2285 H. U1064 H. U1096 H
SCM B0854 H
B0-RFA NO COMM.
I wanted to get to the receiver box to check connections above the left rear wheel but it appears the panel is glued in. Any tips on removing it?
Yuck! Just out of curiosity, did you look under the passenger
kickboard to see if you had any "guests" or water drippings
this winter?
Did the car start? All those comms errors sounds ominous...
All those "U" codes indicate that two of the computers can't talk to
each other. Each of the computers is a "peer" on the network, so
this sounds like more than a ground fault. It almost sounds like the
bus has been disconnected somewhere. Luckily, all the big-guys that
run the car seem to be happy, but the door computers are out to lunch.
It sure does look like it's a fuse or some other large disturbance in
the force.
I don't think it has anything to do with the RFA receiver.
Stupid computers.
Glad to hear you're up and running!
Head unit bad? Check EBay - there's a ton of stock GM radios listed.
I too have a 2000. I tried disconnecting the battery several times for a couple of minutes to no avail. The battery is fresh and the terminals clean. I also located the receiver and disconnected it and pulled it out. It looked fine. I then reconnected it and re-installed it. Same error.
Also, fuse #27 in the passenger footwell checks ok. I'm stumped...
Next step is to check if voltage is actually reaching that receiver,
and if the ground lead shows low resistance to ground.
If that checks out, then I'd say you're in the market for a new
receiver. If not, then some more quality time with the wiring
harness is the order of the day.
Digital computers are the easiest way to implement all the toys.
One man's trash is another man's treasure.
Active handling is the classic case. I thought it was crap at first,
too, until it saved my bacon on a coolant slick out on the racetrack.
Another case: the coupes have antennas in the glass, front and rear.
Normally, having two antennas creates destructive interferance,
which is why most antennas-in-the-glass cars just have one.
But with one, you get lousy reception. With two, you have to do
some digital signal processing to properly combine the two signals,
and then you get *better* signal quality than with just one antenna,
but you need a DSP, i.e. a computer.
I do think the computers in the doors are excessive, but by making
them large-format and hanging them in the door, it's probably
cheaper than trying to minaturize them and stick one under the
dash somewhere.
And just for the record, there are plenty of cars running around
with LS1s out there with all the "crap" flashed out of them.
But guess what? They're not Corvettes.
dash somewhere.
