Oil Filter's Leaking, Not tightened enough?
Old Mar 12, 2007 | 12:37 PM
HollywoodFRC's Avatar
HollywoodFRC
Default Oil Filter's Leaking, Not tightened enough?
Changed oil yesterday and noticed a coating of oil on the outside of the NAPA Gold filter and oil spray on the oil pan itself. Looks like the filter is leaking at the seal. I hand tighten the filter, then tighten (with an oil filter wrench) 1/4 to 1/3 turn afterwards. Been doing this for 30 years on cars and never had one leak. Am I doing something wrong? Is there a torque spec for C5 oil filters? Is the tightening process different? It baffles me. Any suggestions would be appreciated. I don't want to overtighten the filter on one hand, but on the other hand I don't want an oil leak under the car.
Old Mar 12, 2007 | 01:40 PM
hotwheels57's Avatar
hotwheels57
Did you apply a little oil to the seal? That allows the seal to slide a little easier when you hand tighten.
Old Mar 12, 2007 | 02:21 PM
jo8243's Avatar
jo8243
Are you sure it's not the sensor right above the filter (oil temp sensor I believe)?
Old Mar 12, 2007 | 02:41 PM
Billf6531's Avatar
Billf6531
... and finally, did you ensure that the seal from the old filter was not stuck to the sealing flange?
Old Mar 12, 2007 | 03:54 PM
chaase's Avatar
chaase
St. Jude Donor '12
Hand tight plus a little extra using some old oil on the seal to help it out.
Old Mar 12, 2007 | 04:01 PM
rpm462's Avatar
rpm462
Have heard of this happening numerous times.
Old Mar 12, 2007 | 08:37 PM
TEXHAWK0's Avatar
TEXHAWK0
If you cannot tighten the filter a little more by hand when the engine is cold, I would remove the filter and check the gasket. If everything looks alright, I would probably just install a new filter. If you find the gasket is damaged, then get the parts store to replace it.
I assume you put a film of oil on the filter gasket before you installed it?
Old Mar 12, 2007 | 09:58 PM
Zrod's Avatar
Zrod
On my 01 the torque spec for the oil filter is 20ftlbs of torque.
Old Mar 12, 2007 | 10:04 PM
Oldvetter's Avatar
Oldvetter
The torque on the oil filter is 22 ft-lbs, this always amazes me. This is two full turns after contact. Maybe I now know why?
Old Mar 12, 2007 | 10:24 PM
Zrod's Avatar
Zrod
Yep, you're right. Sorry for the mis-info.
Old Mar 13, 2007 | 01:16 AM
HollywoodFRC
Default Now I understand
1) yes I pre lubricated the filter
2) yes, I made sure the old seal came off with the old filter
3) It's already a new filter
4) Now I know why it leaks, need to torque it down, the old hand tighten then a 1/4 turn shade tree mechanic's way doesn't work in this case. Need to torque it to 22 ft lbs
5) Never owned a car with an oil filter torque spec
Thanks for the torque spec!
Bulletin - I picked up about 8 -14 PSI in oil pressure. I normally would register about 40-42 PSI oil pressure before I tightened the filter to spec. I'd max out about 62 PSi on hard acceleration. Since I torqued the filter to spec, normal PSI jumped to 48 - 50 and max jumped to around 80 PSI on WOT. Makes a diffference
Last edited by HollywoodFRC; Mar 13, 2007 at 05:29 PM. Reason: Follow up observation
Old Mar 15, 2007 | 06:24 AM
Oldvetter's Avatar
Oldvetter
Did you change oil filter type? If not, did your car use a lot of oil? If so, you were probably leaking oil (hard to believe). BTW, I was told that the filters will bypass at 74 psi.
I always did contact then 3/4 to 1 full turn, oil filters tell you this too. I do use 22 ft-lbs on my C5.
Old Mar 15, 2007 | 01:00 PM
bighank's Avatar
bighank
Default filter leaking
I ALWAYS tighten all oil filters 3/4 to 1 full turn AFTER they first contact the gasket. Pre oil the gasket with a finger dipped in the new oil and tighten as above. Once oiled my then gfs driveway with my old chevy which I only tightened about 1/3 turn past contact. Tighter is BETTER! BIGHANK
Old Mar 15, 2007 | 07:19 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
You need to be certain there was no leaks prior to your discovery.
  • Get the car up in the air.
  • Remove the new filter.
  • Using a good light inspect the filter flange or gasket surface to be certain there is no damage.
  • Look for other possible leaks in the area
  • Fill new filter with oil
  • Lubricate new filter seal.
  • Tighten by hand then an additional 1/3 turn with suitable wrench.
Old Mar 15, 2007 | 08:34 PM
gpotski's Avatar
gpotski
Old Mar 19, 2007 | 04:20 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
You want to use new oil on the seal,there will be sediments in the old oil.
Old Mar 19, 2007 | 04:22 PM
DA KAR's Avatar
DA KAR
Lately I've been tightening oil filters a little more with the wrench.Maybe I'm getting weaker as I 'm getting older.
Old Mar 19, 2007 | 11:21 PM
HollywoodFRC
Default I was blind ,now I can see
Got my copy of the 1999 3 volume service manual and yep, there's actually a torque spec on the filter - 22 ft lbs. The days of hand tight and a little more twist is old news. These manuals are the best investment you can make if you plan on maintaining your C5. Learn something every day.
Thanks for all the information and advice.
To Oil Filter's Leaking, Not tightened enough?
