Lean Codes!
Old Mar 12, 2007 | 08:14 PM
TYSON1997's Avatar
TYSON1997
Default Lean Codes!
Anybody know if there is a specific afr that will correlate with a lean code assuming all 02 sensors are in proper working condition obviously.
Old Mar 12, 2007 | 08:58 PM
jers98vet's Avatar
jers98vet
What codes are you getting? If you're getting both bank 1 and 2 I'd check for a vacuum leak somewhere between the MAF and the upstream O2's. I believe that the fuel trims are what cause you to get lean/rich codes. Having access to a scan tool would be a great help.
Jer.
