ABS & Traction controle
i hope i am posting this in the rite place
yesterday i took my Z06 for letel blast dawn the road and sudenly the traction contore and ABS light came on and the onboard computer regesterd
service traction controle and ABS
it did this twice so i slowd doan and i stoped turnd the car of and started it again and the lights went of , so i drove it again and i stepd on it once more and the same thing hapend the lights came on once again so i did the same thing stopd the car turnd it of and the lights went of ??????
can some one help me with what should i check or what should i do becouse i feel afraid that if it hapens again i can luse the car and have an accedant
thanks
sensor jacks . Scroll further in threads till you find abs lights when hit bumps. I fixed mine last weekend.
Good Luck,
Tony S
You might be able to clear codes by resetting system. Hit the reset button. Then turn off the TCS, but leave the AH system on (if you have it). That would put you into competition mode. Then go let loose. Should have problem unless you get car out of wack and engage AH system. Warm your tires up a little before you do this by speeding up and braking straight line.
