Fuel Hood release doesn't work
Old Mar 14, 2007 | 02:58 PM
okc50th's Avatar
okc50th
Default Fuel Hood release doesn't work
My release in the console to open the fuel hood doesn't release and I have to use the emergency release in the back. Do you think it is the switch or is their a fuse somewhere? HELP
Old Mar 14, 2007 | 03:12 PM
HeadHunter1's Avatar
HeadHunter1
there is a fuse, but I don't have the number here at work. Also, if the console has been out recently, it is easy to forget to plug the switch back in. Those are the first two things I would look at first.
Old Mar 14, 2007 | 03:23 PM
okc50th's Avatar
okc50th
Thanks headhunter, I looked at a manuel online and it states it is fuse number 32. Where is the fuse box inside the car. It states it is on the passengers side?
Old Mar 14, 2007 | 04:11 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
It is on the passenger side.
Take up the passenger side floor mat, against the firwall you will see two black latches. Unlatch them and you will have access to the fuse block
Old Mar 14, 2007 | 05:18 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
More than likely the plug came loose from the switch, you'll have to lift the center console up to get at the plug.
Old Mar 15, 2007 | 06:36 AM
HeadHunter1
This is easy to get out if you need to go there. Open up the console door, pull up on the traction control switch. There are 4 10 mm nuts/bolts and out it comes. The two back nuts are under the little plastic covers at the back of the console.
To Fuel Hood release doesn't work
