How to remove MAF from Blackwing...??
Old Oct 11, 2001 | 01:41 PM
C5XTASY's Avatar
C5XTASY
Default How to remove MAF from Blackwing...??
I want to remove my Granatelli MAF from my Blackwing to clean it (the MAF). It's been installed for about 4-5 months. I loosened the clamp but cannot get the MAF to budge. Is there a trick that anyone knows to begin to get it moving, or just use elbow grease? Also, if I get it off, should I lightly silicone the rubber to prevent this issue from happening again? Thank for the help!
Ed
[Modified by C5XTASY, 11:48 AM 10/11/2001]
Old Oct 11, 2001 | 02:07 PM
LS1A4's Avatar
LS1A4
3rd Gear
Default Re: How to remove MAF from Blackwing...?? (C5XTASY)
Ed,
Take the Blackwing and MAF out of the car. Use a hairdryer to warm the plastic housing of the Blackwing into which the MAF is inserted. This will expand the plastic and make removal a lot easier.
Hope this helps,
John
Old Oct 11, 2001 | 04:21 PM
C5XTASY's Avatar
C5XTASY
Default Re: How to remove MAF from Blackwing...?? (LS1A4)
This is a good idea. Anyone else? Thanks!
Ed
Old Oct 11, 2001 | 04:35 PM
YO-EL's Avatar
YO-EL
Twist as you pull. Do not pull straight, you'll never get it.
Old Oct 11, 2001 | 06:07 PM
carpe dm's Avatar
carpe dm
The hair dryer is a good idea. Put a LITTLE grease around the connection before re-assembly and you won't have this problem next time. I always use a dab of dielectric or silicone grease for this and have not had a problem. :)
To How to remove MAF from Blackwing...??
