Coolant Temps
Old Mar 14, 2007 | 10:10 PM
TBZ06's Avatar
TBZ06
Default Coolant Temps
I am looking to see if anyone can give me the normal operating temp for the coolant on a 2004 Z06.
The car is operating in the 220 range and the dealer says this is normal.
This seems much hotter than I expected.
Old Mar 14, 2007 | 10:19 PM
corvettedoug's Avatar
corvettedoug
That is normal if you are sitting in traffic on a warm/hot day. I would also check in front of the radiator and a/c condensor (They are on top of each other). These cars suck up leaves, trash, dirt etc which prevent the airflow from cooling.
Old Mar 14, 2007 | 10:20 PM
ALLEGRO's Avatar
ALLEGRO
Our cars are bottom breathers and do not use a fan a nominal operating temps.
The fans begin to come on in the 220's and then switch to high(er) speeds at even higher temps.
Usually you C5 will run cooler n traffic iwith the AC on due to the fans being employed all the time with it is on.
It bothers me too when the temps show the 230's and I always attempt to find a stretch of road without traffic so I can cool her down.
Old Mar 14, 2007 | 10:24 PM
Bill Dearborn's Avatar
Bill Dearborn
Need more info than what you have provided. Where do you see the 220 in traffic or on the highway? Big difference between the two. 220 in traffic is not unexpected. 220 on the highway at 75 mph is too high. 220 on the track at 150 mph is expected unless the radiator is replaced with a racing radiator to get extra cooling. Low operating temps are a thing of the distant past.
Bill
Old Mar 14, 2007 | 11:06 PM
ALLEGRO's Avatar
ALLEGRO
Bill
Usually 192 on the open road or street without many stops.
Traffic is another story. Stop and go is brutal and finds mine as high as 240. It never lasts long due to the fans engaging and moving along in traffic, preferrably without someone directly in front of me.
As mentioned in an earlier post, make very sure that the radiator/condenser is clear of any debris. It is so easy to suck up a Wal-Mart bag or something and really cause a problem.
Old Mar 15, 2007 | 04:38 PM
DannyG's Avatar
DannyG
St. Jude Donor '10
Up here in Washington (around 50 degrees right now) my car runs right around 195-205 on the highway, and cruising around town. In heavy traffic, it gets up to 230-235.
At first I thought that was pretty damn warm, compared to what I'm used to, but these cars are designed to run at higher temps for emission purposes.
Old Mar 15, 2007 | 07:45 PM
Point & Shoot's Avatar
Point & Shoot
My range of temps is anywhere from 194 to 235 depending on driving/traffic conditions - runs great..............
Old Mar 17, 2007 | 12:23 AM
OSCS Ret's Avatar
OSCS Ret
St. Jude Donor '07
Good info as I just had a question about this. Took the vette out today and when I was pulling into the garage after my run, I noticed the temp hitting 210ish... All is normal !
Old Mar 17, 2007 | 09:03 AM
2000BSME's Avatar
2000BSME
Bill
My car is set up (with tstat and fans) to run in the 175-190 range, and I have a noticeable decrease in power if it is 210 or above (supported with time slips). High op. temps are for emissions purposes only. These engines make better power under 200F.
Old Mar 17, 2007 | 09:11 AM
99 vett babycar's Avatar
99 vett babycar
your temps are average. if you'd like to run cooler check for debris on the front of your radiator ( do a search for how to or have your fan temps adjusted.
Old Mar 17, 2007 | 03:16 PM
kevin40zx's Avatar
kevin40zx
Old Mar 17, 2007 | 03:50 PM
hotwheels57's Avatar
hotwheels57
Ambient air temperatures and roadway temperatures will also effect your cooling system temperatures...try driving in 118 degree AZ summer temperatures at rush hour w/o hitting the mid 220s+...
Old Mar 17, 2007 | 05:39 PM
Billf6531's Avatar
Billf6531
Here's what you need to do. Drive on the highway for ten minutes using cruise. Record your temperature - probably 88*C or 190*F. Get someone with HPT or EFILive, nearby, to program your fans to come on 6 degrees higher than the temperature you read, and turn off 2 degrees higher than the temperatures you read. Post on the HPT or EFILive forums for someone near you to help you. For example, I'm in Calgary, and I'll do this, and most other things for an LS1 owner, for a Guinness. Perhaps you'd consider filling out your location profile so your neighbours can step up to the plate and help you.
Old Mar 17, 2007 | 07:18 PM
mellowyellow01vert's Avatar
mellowyellow01vert
Default running hot
I have wondered if removing the thermostat would help us folks here in Florida and elsewhere where the temps are usually above 85.
Thanks,
Joe B.
Old Mar 17, 2007 | 07:28 PM
2000BSME's Avatar
2000BSME
Thanks,
Joe B.
I wouldn't do that. Tstat removal can cause overheating, pushing fluid through the radiator too quickly, before it can cool sufficiently. Tstat required.
To Coolant Temps
