Starter Wiring
Purple wire goes to the (small) coil terminal on the solenoid.
The thick red wire, as well as the thin gray and rust coloered wires all attach to the outer large solenoid post.
You'll see the inner large solenoid post has a braided strap that connects directly to the starter motor, you connect nothing to that.
From the manual:
Important
When installing the purple starter motor lead wire, orient it upwards to the 10:00 position.
Install the starter motor S terminal washer, purple lead wire and nut.
Tighten the S terminal nut to 4 N·m (35 lb in).
Important
When installing the engine wiring harness leads to the starter motor stud, orient them to the 6:00 and 7:00 position.
Install the gray colored wire from the engine wiring harness to the starter motor stud.
Install the rust colored wire from the engine wiring harness to the starter motor stud.
Install the positive battery cable terminal to the starter motor stud.
Tighten the positive battery cable stud nut to 10 N·m (89 lb in).
Install the intermediate exhaust pipe assembly to the vehicle. Refer to Intermediate Pipe Replacement in Engine Exhaust.
Lower the vehicle.
Connect the negative battery cable. Tighten
Tighten the negative battery cable bolt to 15 N·m (11 lb ft).
