C5 window motor replacement help.
Old Mar 17, 2007 | 07:42 PM
gene-00's Avatar
gene-00
Default C5 window motor replacement help.
Been through the banging, hammering,slamming, button pushing, relay checking phase of my passenger side window motor.
Decided to replace the motor and regulator.
Been all over the site and cannot find a how/to regarding this job.
I've had the panel off several times but have never snaked out a motor and regulator.
Any help would be appreciated.
Old Mar 18, 2007 | 12:52 AM
romeorn's Avatar
romeorn
Default Removal of door panel
I found this link on this site. I too have a similar problem - the passenger window - now going on two weeks. I just haven't the time to work on it yet.
According to Dustie
CF Senior Member
http://www.vetteessentials.com/instr...or_handle.html
Old Mar 18, 2007 | 02:06 PM
imiuru's Avatar
imiuru
just had this issue with my pass window, wouldn't work all of a sudden. Pulled the panel off, the motor was getting really hot, had voltage, seemed like it was bound up. Was going to replace and waited another week, that regulator assembly is expensive. then one day I slammed the door and the thing works now. Have no idea why or how, but it freed itself up.
Old Mar 19, 2007 | 08:15 AM
gene-00's Avatar
gene-00
Thanks for the link.
I appreciate you getting this info for me
Old Mar 19, 2007 | 08:28 AM
RobertEarl's Avatar
RobertEarl
The brushes are probably just stuck. This happens a lot on the passenger side as it is not used very much. You can take the door panel off and then the speaker. After that you can use a torx ( sorry I don't remember the size ) to remove the 4 bolts that hold on the motor housing. Spin the armature a few time to loosen up the brushes and put it back together. It only takes about 15 minutes and is free. If you will just lower the window once a week or so, it should last a long time.
Reb
Old Mar 19, 2007 | 08:44 AM
gene-00's Avatar
gene-00
Thanks Reb,
This has been a long standing or should I say often repeating problem[car is a 2000].
I have tried all the tricks which work for a short while.
Decided finally to bite the bullet and install a new motor and regulator.
Could really use some how/to on the actual mechanical aspect of this job.
Has anyone ever replaced one of these units or know of a link to help?
Thanks,
Gene
Old Mar 19, 2007 | 03:07 PM
c3andc5's Avatar
c3andc5
Originally Posted by gene-00
Thanks Reb,
Thanks,
Gene
I asked the exact same question the day before you did. Seems noone on this forum has tackled that task. I've sized it up and it looks like a tough one. I think I'll try to take the motor off and spin the armature like RobertEarl suggested. Otherwise, it's a new motor/regulator assembly for me. I'll figure out how to get it in when the time comes.
Old Mar 19, 2007 | 03:40 PM
Hvymtlc5's Avatar
Hvymtlc5
twas easy to replace...door cavity on a C5 is like a big empty cave. Regulator is just a motor and platic track...bolts in and out. Door panel wasn't hard at all nothing hidden that I remember....we waited a year to do my son's because we thought it would be difficult....not so.
Old Mar 19, 2007 | 04:45 PM
in2fun's Avatar
in2fun
I have replaced mine and my friends. It is not hard at all. Only thing is don't get rushed.
Make sure you mark the old glass as it sits on the window clamps... this will save you some time on the ajustments of the window.
Also mark were the tip-in window ajustment is ( its on the lower forward part of the door-underside of door .
Also mark were the ajustment is on the lower left of the door panel ( drivers side ) lower right ( passengers side ).
making a note and marking were the window was before on the old regulator with help save you time and #@$! ajusting the window.
If you guys live in the Dallas/Ft, Worth are, let me know and I'll give you guys a hand !
Old Mar 19, 2007 | 06:00 PM
gene-00's Avatar
gene-00
Hey Thanks much!!
That's the kind of info I was looking for.
As usual, some hints as what to look out for can often save a bunch of time.
I already have the parts and I'll tackle the job this week.
Appreciate your help,
Gene
Live in SC. but thanks for the offer of help.
Old Mar 19, 2007 | 09:06 PM
in2fun's Avatar
in2fun
OK here are some pics I did to better explane.
[IMG][/IMG]
Old Mar 19, 2007 | 09:08 PM
in2fun's Avatar
in2fun
Here is the window clamp bolt. make shure and mark here too.
[IMG][/IMG]
Old Mar 19, 2007 | 09:10 PM
in2fun's Avatar
in2fun
Here is the ajustments openings on the lower forward part of doors
[IMG][/IMG]
Old Mar 19, 2007 | 09:14 PM
in2fun's Avatar
in2fun
Here is the tip-in bolt ajustment on lower front under door.[IMG][/IMG]
Old Mar 19, 2007 | 09:16 PM
in2fun's Avatar
in2fun
Here is the lower left ( drivers side ), lower right ( passengers side ) Ajustment.
[IMG][/IMG]
Old Mar 19, 2007 | 09:24 PM
in2fun's Avatar
in2fun
Here are the ajusment bolts with the door panel on. Try to get all your ajustments done before you put the panel back on. But if need be... you can fine tune here with panel on. ALSO !!!!! DO NOT FOR GET TO HOOK BACK ALL WIRING BEFORE YOU PUT DOOR PANEL BACK ON !!!!!!!!! Put a sticky note on door panel to remind you of this ( check wiring hook ups ). I made this mistake... friend called, I was talking to him as I was doing the last steps and forgot to hook up wires... NEVER AGAIN ! Last advise TURN PHONE OFF.
[IMG][/IMG]
Old Mar 20, 2007 | 08:33 AM
gene-00's Avatar
gene-00
Whoa am I glad to see this before I began the job.
I really would have been in deep dog droppings without it.
Really, really appreciate your effort to help me out.
Thanks,
Gene
To C5 window motor replacement help.
Old Mar 22, 2007 | 08:10 AM
Anthon's Avatar
Anthon
Cruising
Thank you guys. Illustrations are surely a great healp. My friend phoned me last night on getting his new chevy window motors in placed. But i never tried it before.
Old Mar 22, 2007 | 09:40 AM
jmiller's Avatar
jmiller
Good Information. I've replaced mine 3 times. I've done the passenger side twice, and the driver side once. I purchased used units off ebay. It's really not difficult. You just have to tweak the alignment to get the glass just right.
I would recommend you purchase a new unit. It's more expensive, but it should last awhile.
I tried taking the motor apart, checking out the brushes etc. I also disassembled the spool. It took several hours to get it all back together, and it worked. For 2 days.
Buy new and be done with it. Gene Culley will get you the best price.
Old Mar 23, 2007 | 06:47 PM
in2fun's Avatar
in2fun
I Agree. A new one is best, but they are so expensive. I got mine from Window Lift in Florida ( they are good guys and they stand behind there stuff ). I have not had any prob. with mine nor my budies. I have hand mine on for less then a year with no prob. But the one we installed on my budies vette is going on just over 2 years with no probs. One thing for sure... don't mess with the old one. I too thought I had mine fixed, re-installed it and lest then one full day, it went out again.
So just get another one and install it ( A new one, if you can take the hit ).
