Any Tranny pros out there
I luv the sound and performance while driving in 1st, 2nd, 3rd, always shift into OD only when I am on the hwy doing 70mph or more.
What is the safiest I can drive 1st,2nd, 3rd up to as far as RPM's.
Thanx folks
computer drive the car and have actually proven it to some guys that manually shifting makes the car slower than if you just put it in "D"
Thanx for the input
As for the Temps I noticed a significant increase in Transmission temps manually shifting which is why I had RevXtreme put twin transmission coolers on.
I live in Florida so the temps are arond 75+ degrees outside air temp:
When leaving it in 3rd or OD temps would range from 180-200.
When Manually Shifting 1-3 Temps jumped to 200-227
My buddy Terry with a C5R told me that anything near 230 was not good.
After the Trnsmission coolers installation the temps are as follows:
Leaving it in 3rd or OD 140-160
Manually Shifting 1-3 150-160
I haven't seen it over 160 since I have had the new setup so I am going to do a gear swap and stall convertor with them when I return.
As far as the shifting it 6K should be fine just makes more heat obviously
Hope this helps James.
