AFR Heads - FREE Shipping!
Old Mar 18, 2007 | 04:52 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Default AFR Heads - FREE Shipping!
We're offering FREE shipping for all of the AFR heads that are ordered through Sunday, March 25th!
205cc LS1 Mongoose Street Head
The Small Port, High Velocity Torque Monster! For the ultimate street LS1/LS2/LS6 aluminum cylinder head AFR’s all new 205cc emission legal cylinder heads E/O # D250-4 are your only choice. Specifically designed for 1997 to present Gen-3 Chevy Corvettes, Camaros, and trucks. AFR’s LS1 head offers unmatched flow performance (298 CFM at .600lift) and features 2.020 intake and 1.600 exhaust valves with AFR’s iron ductile interlocking valve seats. With only 205cc port volume (same as stock LS1 head) this is an incredibly 70 CFM increase over stock casting creating unbelievable port velocity and performance. The 205cc is ideal for normally aspirated 346C.I. to 396C.I. It is available with 66cc and 76cc combustion chambers. AFR’s LS1 is a direct bolt on, no special parts required. Structural features like Air Flow Research’s trademark 3/4” thick head deck, a must for blown and nitrous applications, reinforced rocker stud bosses, and thick wall runners provide unparalleled durability. An exclusive new modern combustion chamber design with double quench pad area helps the LS1 generate huge low and mid lift airflow numbers. If you need a snake charmer for that pesky neighborhood “Cobra Mustang” look no further.
225cc LS1 Mongoose Strip Aluminum Cylinder Heads
The Ultimate Bolt-On Emission Legal Street/Strip Weapon
For the maximum street/strip LS1/LS2/LS6 aluminum cylinder heads AFR’s all new 225cc emission legal head E/O #D250-4 are hands down the best choice. Specifically designed for 1997 to present Gen-3 Chevy Corvettes, Camaros, and trucks. AFR’s LS1 head offers unmatched flow performance and features 2.080 intake and 1.600 exhaust valves with AFR’s iron ductile interlocking valve seats. The 225cc is ideal for normally aspirated 396C.I. to 427C.I. For a wild 346 ci the 225 is a good choice, however some low RPM loss of torque might occur. It is available with 62cc, 65cc, and 72cc combustion chambers. AFR’s LS1 is a direct bolt on, no special parts required. Structural features like Air Flow Research’s trademark 3/4” thick head deck, a must for blown and nitrous applications, reinforced rocker stud bosses and thick wall runners provide unparalled durability. An exclusive new modern combination chamber design with double quench pad area helps the LS1 generate huge low and mid lift airflow numbers.
Prices can be seen in the Valvetrain sections of our website or by giving us a call at 1-877-4-TBYRNE (1-877-482-9763).
Have a good day!
Old Mar 27, 2007 | 08:44 AM
tbyrne's Avatar
tbyrne
bump
