Bbk Throttle Body Help
Old Mar 19, 2007 | 08:54 PM
attyman1968's Avatar
attyman1968
Default Bbk Throttle Body Help
I am installing a BBK throttle body on an 01 Z06. In the box was an adapter plate about 3/4 inch thick. It doesn't appear I need this but hey, what do I know. Am I to use this between the intake and throttle body even though the width of my original tb and the BBK are the same? Thanks
Old Mar 20, 2007 | 04:48 PM
Last C5's Avatar
Last C5
It's not really an adapter plate, if you look closely you'll see that it's mini venturi tube of sorts. It necks the 80mm TB down to 78mm to meet the opening in the intake manifold. Make sure that you put the larger side toward the new TB. I also had to use the BBK supplied spacers to move the power steering pump bracket out from the block about 1/2".
Old Mar 20, 2007 | 09:10 PM
vetred's Avatar
vetred
I had Cory "PORT" my LS6 Intake manifold and the new BBK 80mm will fit perfect! hes at http://www.ls2portworks.com/ did a great job for me!
To Bbk Throttle Body Help
