Better Gas Mileage??
Old Mar 20, 2007 | 10:10 AM
Nick1's Avatar
Nick1
Default Better Gas Mileage??
Will you get better mileage with particular brands of gas or higher octane? Thanks
Old Mar 20, 2007 | 10:36 AM
VetteDrmr's Avatar
VetteDrmr
My experience has been that brands of gas act pretty much the same, with one major exception:
If you buy "blended" fuel (10% ethanol), you will get about 10% worse mileage. I've personally experienced that on the three family cars that I drive and keep records on.
The rule of thumb concerning octane ratings is to run the lowest you can without experiencing knock (i.e. detonation). The problem with our LS-x engines is that they all contain knock sensors, which will pull timing (and therefore efficiency). Our engines have pretty high compression ratios, and will experience knock retard with anything lower than 93 octane (and even some there, but 93 is about the best you can find in general).
HTH, and have a good one,
Mike
Old Mar 20, 2007 | 11:11 AM
nickolbag's Avatar
nickolbag
A few years ago Shell advertised better gas milage with their gas. I tested it out on my Saturn. 3 full tanks of all the gas stations around my house. Ran them all from full to empty and averaged them out. It turned out that they were all pretty mcuh the same except for Shell. I actually did get better gas milage back in 2003 when I did this. Significant difference too, 5MPG. However this was just my little test and not some big scientific study but it made me happy enough to keep going to Shell.
Old Mar 20, 2007 | 11:25 AM
robert123's Avatar
robert123
All the same for me . Should all be the same , just watch for octane rating.
Old Mar 20, 2007 | 03:44 PM
rws.1's Avatar
rws.1
Each refinery produces a different mix of hydrocarbons which are blended to create a broad spectrum product called gasoline.
Since raw gasoline is swapped between producers the only real difference that the consumer may notice is additives.
If you can be sure that all the gasoline from one brand comes from only one refinery and no other brands are serviced by that refinery, you might be able to detect mileage differences...
However additives do create bette driveability, smoother idle, less hesitation and cleaner engines ( less deposits = more horsepower and less knock)
I can notice the difference in driveability between brands. I stick with Shell V-Power where ever it is available.
Old Mar 21, 2007 | 11:26 AM
Nick1's Avatar
Nick1
Thanks for your input!
Old Mar 21, 2007 | 07:52 PM
BanditDude's Avatar
BanditDude
91 octane is the best I can find at most stations, and it works very well.
To Better Gas Mileage??
