ls6 intake swap question
Old Mar 20, 2007 | 10:10 PM
123sugey's Avatar
123sugey
Dig
Default ls6 intake swap question
Can You Simply Swap Out A 97 Ls1 Intake For A Ls6 ?
Will The Ls1 Throttle Body Be Ok ?
Any Complications ?
Thanks.........
Old Mar 20, 2007 | 10:19 PM
FRC Rob's Avatar
FRC Rob
Throttle bodies are the same. The ls6 manifolds are flat on the bottom, and will interfere with the older LS1 "1 piece" coolant tube assembly underneath the manifold. You can either purchase the smaller late model LS6 front coolant tube assembly and 2 rear coolant plugs. Or, you can use a dremel tool to grind down some of the ribs under the LS6 manifold for clearance with your older style coolant tubes.
Old Mar 20, 2007 | 10:30 PM
123sugey's Avatar
123sugey
Dig
thanks for the info
To ls6 intake swap question
