Interior Bulbs
Old Mar 22, 2007 | 05:06 PM
B-rent's Avatar
B-rent
Default Interior Bulbs
Does anyone know how many of the small bulbs are used in the interior? Im talking about the size that go in the door panels, under the traction control button, ect.
My car is in the shop so I cant go out and count myself
Old Mar 22, 2007 | 05:18 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Doors - 5 (6 if you have memory)
DIC Buttons - 3
Fog/Trunk - 1 (2 if you have Fog lights)
Tracion/Active Handeling - 2
Old Mar 22, 2007 | 05:38 PM
B-rent's Avatar
B-rent
thanks
Old Mar 22, 2007 | 05:48 PM
drbvac's Avatar
drbvac
Default size
Are these the neo wedge 3/8 x 1/2 from autolumination? They are 5 colors, 3 bucks each.
Old Mar 22, 2007 | 05:50 PM
tstar's Avatar
tstar
Yes they fit perfectly... and are plug and play, the resistor is already soldered into the base...
FYI The Neos are polarity sensitive so if they don't light when you first put them in simply remove and reverse...
Old Mar 22, 2007 | 06:05 PM
B-rent's Avatar
B-rent
Just if you guys were wondering im getting a company to make us LED bulbs for the slots at about $2/bulb. Right now the only other LED company I know of charges almost $10 per bulb
Old Mar 22, 2007 | 06:13 PM
tstar's Avatar
tstar
Autolumination sells em for $2.98 a bulb. Your price is better! Man if you could get them to make the smaller bulbs for the HUD/Dimmer that would really be great!
Old Mar 22, 2007 | 06:18 PM
B-rent's Avatar
B-rent
Are Autolumination's LEDs? Also once the company sees how these bulbs sell the might consider expanding to other C5 Bulbs
The other corvette project I convinved them to do are a new style of C6 LED tails
Old Mar 22, 2007 | 06:23 PM
tstar's Avatar
tstar
Yep... LEDs. I installed em!
Old Mar 22, 2007 | 06:39 PM
drbvac's Avatar
drbvac
I did too but paid double that because I bought a "kit" that had the 6 bulbs in it!
Old Mar 22, 2007 | 06:41 PM
tstar's Avatar
tstar
Was that from GS Creations? I thought they used autolumination's Neo Wedge LEDs...
Old Mar 22, 2007 | 07:12 PM
rwlc5's Avatar
rwlc5
Specifically what is the part number of the bulb from autolumination?
Old Mar 22, 2007 | 08:09 PM
tstar's Avatar
tstar
There is no part number per se... Go to this website;
http://autolumination.com/74.htm
Scroll about halfway down the page until you see this bulb;
Neo - Wedge Instrument Panel Bulbs are 10mm (3/8") diameter x 13mm (1/2") high
*Images*
Order Neo Wedge Based LED Bulbs (shown above): $2.99 ea.
Choose Color
1 Led Lens
Add to Cart
Old Mar 22, 2007 | 08:26 PM
B-rent's Avatar
B-rent
Thats who I got a kit from at 6 bulbs for $50....product was fine, I just decided that they couldnt possibly be that expensive to get from other place. Worst case this other company thats going to produce then (they are very well know for quality LED's) will be about .50 per bulb cheaper than autolumination
Old Mar 22, 2007 | 08:37 PM
B-rent's Avatar
B-rent
Anyone else interested in getting this bulb made into an LED from this company?
Old Mar 23, 2007 | 02:31 AM
tstar's Avatar
tstar
I know there will be a demand especially if they can make the smaller HUD/Dimmer switch ones...
The HUD/Dimmer bulb is on the left. I did Red bulb covers to change my lighting BTW...
Old Mar 24, 2007 | 11:11 AM
drbvac's Avatar
drbvac
I have red leds in the doors and they look good! Anywhere else, footwells, trunk etc, not bright enough to see the mats, Just ordered the 194 and flat cluster bulbs from autolumination.
To Interior Bulbs
Old Mar 24, 2007 | 05:10 PM
tstar's Avatar
tstar
Let me know how you like them, I have the Super Matrix 194 and they are OK, not the brightest but not too bad either... I'll try and get a pic and post it after it stops raining here.
Old Mar 24, 2007 | 05:57 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What bulbs size fits where ?
I want to put led lights in the
Door Controls
Dash / Instrument both sides switches
HVAC Control
Rear View Mirror
Door Panels
Thanks for any help. Do Autoillumination bulbs come with the resistors installed ?
Old Mar 24, 2007 | 11:20 PM
tstar's Avatar
tstar
Yes the Autolumination Neo Wedges have the resistor already installed. LED Mod Parts List
Switches and Buttons (Add 1 each for Fog lights or Memory)
11 ea. – NEO WEDGE bulbs. 10mm (3/8”) diameter x 13mm (1/2”) high. $2.99 ea.
Dimmer ( Add two if you HUD)
1 ea. - 3mm LED's with resistors
http://www.oznium.com/led
OR
1 ea. – NEO WEDGE bulb. 10mm (3/8”) diameter x 13mm (1/2”) high. $2.99 ea.
Remove the LED from it’s base and solder directly unto the board or you can try and shave the top of the original base after removing the bulb and see if the LED will fit.
Under Dash and Cargo Area
4 ea. – 194 Matrix Super Star bulbs. 10mm diameter x 26mm overall $7.99 ea.
http://autolumination.com/194.htm
Map Lights for 97s thru 99s (00s thru 04s have LED Arrays
2 ea. – Festoon 2 LED bulbs. 10mm wide x 44mm overall length. $9.99 ea.
http://autolumination.com/festoon.htm
HVAC controller (Leaving stock orange LEDs in)
14 ea. - 3mm LED's with resistors.
While you’re in the HVAC check the other board for cold solder joints on the “241” resistors.
Bose Radio/CD Player
10 ea. - 5mm LED's with resistors.
There's a ton of info in the Thread I'm in, just takes awhile to go throught the Thread;
http://forums.corvetteforum.com/show....php?t=1588861
