240 dollars for relay problem
Old Mar 23, 2007 | 01:59 PM
tigerman's Avatar
tigerman
Default 240 dollars for relay problem
My brother took his 03z to the dealer yesterday (dic said service column lock) they said the recall was already done, they would call him later. he got a call today saying it will be 240 dollars it is the relay..
opinions please..thanks
shouldn't this be covered on the recall?
Old Mar 23, 2007 | 04:24 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Get the bypass kit, the M6's recall never worked correctly.
Old Mar 24, 2007 | 12:37 PM
midnightc5's Avatar
midnightc5
I'm going through the same problem. The dealer should
cover it! They tried to make me pay for it saying the
recall was already performed. I went to the service
manager and told him about the "Special Policy Adjustment-
Electronic Column Lock System #05081 issued (02/08/2006)"
which basically warranties the work done on the CL till feb.08!
They'll try and make you pay unless they know you've done
your homework! When I threw this at them, they squirmed and
immediately said they'll take care of everything at no charge to
me. Mine also had the recall done and now went back for CL plate
removal and new relay harness. Hope this helps. Any questions,
feel free to call me. PM'd you my cell #
Good Luck!
To 240 dollars for relay problem
