Replacing oil pressure sensor need HELP?
Old Mar 24, 2007 | 10:31 AM
PugLover's Avatar
PugLover
Default Replacing oil pressure sensor need HELP?
I know I read how much to tighten the sensor and the intake to but can not find it again. I have my intake off and sensor out. PLEASE HELP. I'm a weekender so this is a big project for me. Don't know if it matters but I have an 01 vert. Found this is it correct?
Torque values:
oil pressure sender: 15 ft-lbs
intake bolts: 44 in-lbs first pass, 89 in-lbs second pass
Mark
Old Mar 24, 2007 | 12:44 PM
mnotx's Avatar
mnotx
Those are correct for the 2003. Should be the same for yours.
Old Mar 24, 2007 | 05:34 PM
berryj's Avatar
berryj
http://forums.corvetteforum.com/show...ght=change+oil
Old Mar 24, 2007 | 11:24 PM
rws.1's Avatar
rws.1
They are correct for an '01... did my changeout last weekend.
Old Mar 25, 2007 | 09:36 AM
Classical Glass's Avatar
Classical Glass
If you still have the old oil pressure sensor I would be glad to buy it from you. I need the outer casing, Thanks...
Old Mar 25, 2007 | 09:38 AM
PugLover's Avatar
PugLover
Default Have it no cost.
pm me your address and I will mail it to you. No cost.
Mark
To Replacing oil pressure sensor need HELP?
