P0332 code, Help please
Old Mar 24, 2007 | 01:01 PM
projectnightmare's Avatar
projectnightmare
Default P0332 code, Help please
p0332 - What would be causing the code?
it's ping sensor 2, low input...
Old Mar 24, 2007 | 02:35 PM
dpd's Avatar
dpd
there's a tech bulletin on this.it has to do with water ingress into the rear knock sensor.this especially happens if you wash the engine.the fix is pull the intake,replace the knock sensor,reseal both front and rear grommets,clean/replace all corroded terminals.
