Polished Center Caps
Old Mar 24, 2007 | 02:37 PM
SCPDLARRY's Avatar
SCPDLARRY
Default Polished Center Caps
What is the safest way to remove a C5 polished center cap
to prevent snapping off a plastic clip or chipping the cap?
Old Mar 24, 2007 | 08:45 PM
Burgie's Avatar
Burgie
I took a wire coat hanger, made a small 1/4" hook at the end and after placing it down the lug nut hole, place the hook part under the cap and give a snug (pull). Works for me-
Old Mar 25, 2007 | 12:25 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Just grab it with your fingertips and pull it straight off; you're making this too hard. If you can't get enough of a grip, and you're planning on taking the wheel off, just remove a couple of the lugs so you have more room to grab it. You won't break or bend anything.
To Polished Center Caps
