P0343 CMP Sensor Circuit High Voltage
Old Mar 24, 2007 | 06:43 PM
Mike04's Avatar
Mike04
Default P0343 CMP Sensor Circuit High Voltage
I have the P0343 code...
So it could be;
- Foreign material passing between the sensor and the reluctor ring
- Wiring routed too close to secondary ignition components
- Poor connections
- Camshaft reluctor wheel damage
- The sensor coming in contact with the reluctor wheel
- Cam bolts coming loose
Any inputs on good trouble shooting, short of tearing the engine apart to check the cam bolts.
Where is the sensor located, pics would be great.
I have a HP Tuner, is there any way to check the sensor/ troubleshoot with it? I see that there is a PID for Engine diagnostics; cam sensor high to low and cam sensor low to high.
Old Mar 25, 2007 | 08:00 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I just read somewhere somebody had that,It turned out to be the cam bolts were loose.I don't know if thats what you have,But its in your list..................Paul
Old Mar 25, 2007 | 10:03 AM
Mike04's Avatar
Mike04
That seems to be the main cause of the code. That is a lot of work to do just to tighten 3 bolts
Old Mar 25, 2007 | 12:57 PM
1 Nasty Z's Avatar
1 Nasty Z
Did you use locktight on the bolts of the cam when you installed the blower? I know this sucks. I did mine during my install just to be safe since I was down there pinning the crank I figured it was the right time to do it. Also installed an LS2 timing chain as well. It sucks doing things twice.
Good luck and I would guess its the bolts that have came loose.
Troy
Old Mar 25, 2007 | 02:11 PM
Mike04's Avatar
Mike04
Troy
Never crossed my mind.... Now I'm thinking of a cam
To P0343 CMP Sensor Circuit High Voltage
