HID Install Help
Old Mar 24, 2007 | 10:53 PM
PewterMetallic98's Avatar
PewterMetallic98
Default HID Install Help
I will be installing my new HID kit tomorrow and can't figure out where I should mount the balast at. There doesn't seem to be an easy place to put it. I was probably going to mount them with some super 3M tape. Can anyone provide any pics of their balast installed?
I am also curious about one part of the instructions. It says "Make sure to leave 500mm between the bulb front and the metal shade, otherwise this system may be damaged by electric arc of high voltage." I don't know what the "metal shade" is or what exactly they mean.
Any help is greatly appreciated. Thanks guys!!
Old Mar 25, 2007 | 09:32 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Goto this supporting vendor site; www.djmotorsportaccessories.com He has detailed instructions you can download that should work for you. BTW, the C5 lens doesn't have a metal shade in it.
Old Mar 25, 2007 | 10:25 PM
kringer's Avatar
kringer
I installed mine on top of the fenders right behind the lights you can see the silver box on the right fender. I've thought about moving the to a hidden place but I haven't made the effort. this was an eisy place to mount them.
http://kevin.photosite.com/2000Vette/Picture_045.html
Old Mar 26, 2007 | 07:19 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I put 4 sets so far under the light without any issues.
Another suggstion if you question if the tape will hold is to drill a hole from the wheel well in and then put a bolt through. The self tapping screws they give you make no sense since the point side will be facing the tire.
There are pictures of the install at www.ecsracing.com look under product installation.
Old Mar 26, 2007 | 08:04 AM
ILM-Express's Avatar
ILM-Express
MFIC
I'll take a picture when I get home for you.
Oz
Old Mar 26, 2007 | 11:41 AM
zeevette's Avatar
zeevette
If your HID kit came with metal brackets, that the ballasts slide into, there's a great place to mount them under the headlight buckets. I had to remove the hood stop pins to get my arm in there, but that just takes 15 sec. with a 13mm wrench. Assuming your plastic trim is removed, you can see a large open area under the headlights. There's a couple of bolts protruding from the radiator support/fenderwell area, that have nuts attached. I just used these to mount the furnished brackets, and then slid in the ballasts. This mounts them low, and away from the lowering buckets, and it's mechanism.
Old Mar 26, 2007 | 11:45 AM
zeevette's Avatar
zeevette
And BTW, anybody considering doing this mod, I say do it! I tried them out last night, and the difference is phenominal. When I tried my stock brights, it was exactly like putting on yellow tinted sunglasses.
Oh, and on an install note.... on my kit, I had to reverse the polarity of the modular plugs to make it work. If you clip them together like they're supposed to, they won't work. Just keep black wire, to black wire.
Old Mar 26, 2007 | 07:22 PM
PewterMetallic98
You are THE MAN! I couldn't get them to work for the life of me and I finally reversed the polarity and boom they work! I did find the bolts to mount the brackets on to also. They seemed like they were almost made for them! All I did was hang the bracket on them and use some of the nuts of the bolts that came in the kit. Fit nicely!!!
Thanks for all the links and help guys!!
PS: On a side note....I am having another problem with the headlights in general. I made another post for it just now.
Old Mar 26, 2007 | 09:51 PM
zeevette's Avatar
zeevette
No problem. Glad I could help.
Old Apr 6, 2007 | 12:09 AM
ILM-Express
MFIC
Sorry it took so long.
Oz
Old Apr 6, 2007 | 12:41 AM
lytspeed1's Avatar
lytspeed1
Anyone in the Baton Rouge La. area that installs these things?..I got mine in last week from Tbyrne and am feeling hesitant about putting these things on.....When i did my headlight gear fix(the supposed half hour one)...I m sure I sent my soul to hell several times over....
Old Apr 6, 2007 | 12:42 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
To HID Install Help
