p1416...
Old Mar 25, 2007 | 02:33 PM
jman1's Avatar
jman1
Default p1416...
lots of great info on this code..... 1 question i didnt see answered... i sprayed some fogging oil and some wd down the air hose... then used my compressor to force it down... the air did not flow thru the hose.... is that normal???? it backed up and blew out where i was putting it in...
Old Mar 26, 2007 | 12:05 PM
kevin40zx's Avatar
kevin40zx
I sprayed some cleaner and wd40 in the hose and shot compressed air into it. The air seemed to go through for me. Definitly didn't come back out the hole.
Old Mar 26, 2007 | 11:41 PM
Saving41's Avatar
Saving41
Old Mar 27, 2007 | 06:57 AM
jman1's Avatar
jman1
hmm.... so one of my check valves must be stuck shut
Old Mar 27, 2007 | 01:44 PM
royski's Avatar
royski
Default 1416
you should be able to blow some through if not its the problem try it when cold try it 5 time it should loosen up try p b blaster that stuf dont do it replace the 12.50 per valve you got two have fun make sure all hose connections are tight if any are loose it will throw a 1416 code hope this helps .... Royski
To p1416...
