Why is the PCV valve grounded?
Old Mar 26, 2007 | 02:12 AM
Mike94ZLT1's Avatar
Mike94ZLT1
Default Why is the PCV valve grounded?
Why is there that big strap holding it down where the crossover goes? That's a ground strap, right?
Old Mar 26, 2007 | 02:41 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I also was wondering that
Old Mar 26, 2007 | 04:53 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 26, 2007 | 09:21 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I would say it's just there to hold the valve in place and absorb some of the vibration, think of it like a Barry mount for avionics on aircraft
while you're there, notice the injector grounding strap on the aft RHS fuel rail mount, that is a ground strap
Old Mar 26, 2007 | 09:23 AM
gsxrjack's Avatar
gsxrjack
I thought it was strapped for heat to get to the pvc valve in cold weather or any weather for that matter...thought thats what i read or was told...
Old Mar 26, 2007 | 09:26 AM
SteveDoten's Avatar
SteveDoten
, makes sense
Old Mar 26, 2007 | 11:03 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You are correct. It was mounted wth the large gauge wire for heat transfer purposes only. They wanted to insure that during temperature changes of the outpside air, the valve would continue to operate as designed.
Old Mar 26, 2007 | 11:42 AM
SteveDoten's Avatar
SteveDoten
just an interesting note: 01-04 LS6 motors and the '04 LS1 used the PCV from the valley cover, no strap
Old Mar 26, 2007 | 03:02 PM
ArKay99's Avatar
ArKay99
That is an interesting observation. I have a 99 LS1 but have done the LS6 valley cover mod. I still have my PCV valve strapped. Wonder if I should 'unstrap' it... Guess I could do so and see.
Old Mar 26, 2007 | 03:06 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I don't think it really makes a differece, my new engine will have the LS6 style PCV but I'm going to leave the strap on there.
Old Mar 26, 2007 | 06:50 PM
Oldvetter's Avatar
Oldvetter
I put the PCV in my 1998 C5 that has a small hole in it and NO VALVE. It is for cars that use a lot of oil, it is suppose to keep excess oil out of your intake manifold. I know it is not "an official" fix for the C5 LS1, but it is for many V8's in GM Trucks.
Old Mar 26, 2007 | 08:24 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Have you checked to see if it works?
To Why is the PCV valve grounded?
